Assessing Greenhouse Gas Monitoring Capabilities Using SolAtmos End-to-End Simulator: Application to the Uvsq-Sat NG Mission - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Remote Sensing Année : 2024
Mustapha Meftah
Connectez-vous pour contacter l'auteur
Alain Sarkissian
Slimane Bekki
Pierre-Richard Dahoo
  • Fonction : Auteur
  • PersonId : 921036
Patrick H. M. Galopeau
  • Fonction : Auteur
  • PersonId : 953464
Franck Lefèvre
Alain Hauchecorne
  • Fonction : Auteur
  • PersonId : 914935
Philippe Keckhut
  • Fonction : Auteur
  • PersonId : 918122
Monitoring atmospheric concentrations of greenhouse gases (GHGs) like carbon diox- ide and methane in near real time and with good spatial resolution is crucial for enhancing our understanding of the sources and sinks of these gases. A novel approach can be proposed using a con- stellation of small satellites equipped with miniaturized spectrometers having a spectral resolution of a few nanometers. The objective of this study is to describe expected results that can be obtained with a single satellite named Uvsq-Sat NG. The SolAtmos end-to-end simulator and its three tools (IRIS, OptiSpectra, and GHGRetrieval) were developed to evaluate the performance of the spectrometer of the Uvsq-Sat NG mission, which focuses on measuring the main GHGs. The IRIS tool was imple- mented to provide Top-Of-Atmosphere (TOA) spectral radiances. Four scenes were analyzed (pine forest, deciduous forest, ocean, snow) combined with different aerosol types (continental, desert, maritime, urban). Simulated radiance spectra were calculated based on the wavelength ranges of the Uvsq-Sat NG, which spans from 1200 to 2000 nm. The OptiSpectra tool was used to determine optimal observational settings for the spectrometer, including Signal-to-Noise Ratio (SNR) and integration time. Data derived from IRIS and OptiSpectra served as input for our GHGRetrieval simulation tool, developed to provide greenhouse gas concentrations. The Levenberg–Marquardt algorithm was applied iteratively to ne-tune gas concentrations and model inputs, aligning observed transmittance functions with simulated ones under given environmental conditions. To estimate gas concentrations (CO2 , CH4 , O2 , H2 O) and their uncertainties, the Monte Carlo method was used. Based on this analysis, this study demonstrates that a miniaturized spectrometer onboard Uvsq-Sat NG is capable of observing different scenes by adjusting its integration time according to the wavelength. The expected precision for each measurement is of the order of a few ppm for carbon dioxide and less than 25 ppb for methane.
Climatologie
remotesensing-16-00529.pdf (4.05 Mo) Télécharger le fichier
insu-04550544 , version 1 (17-04-2024)
insu-04550544 , version 2 (18-04-2024)
Cannelle Clavier, Mustapha Meftah, Alain Sarkissian, Frédéric Romand, Odile Hembise Fanton d'Andon, et al.. Assessing Greenhouse Gas Monitoring Capabilities Using SolAtmos End-to-End Simulator: Application to the Uvsq-Sat NG Mission. Remote Sensing, 2024, 16 (3), pp.529. ⟨10.3390/rs16030529⟩. ⟨insu-04550544v2⟩
0 Consultations
0 Téléchargements
