Tropical tropospheric ozone and carbon monoxide distributions: characteristics, origins, and control factors, as seen by IAGOS and IASI - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Atmospheric Chemistry and Physics Année : 2023
Bastien Sauvage
Romain Blot
Damien Boulanger
Hannah Clark
The characteristics and seasonal variability in the tropical tropospheric distributions of ozone (O3) and carbon monoxide (CO) were analysed based on in situ measurements provided by the In-service Aircraft for a Global Observing System (IAGOS) programme since 1994 and 2002, respectively, combined with observations from the Infrared Atmospheric Sounding (IASI) instrument on board the MetOp-A satellite since 2008. The SOFT-IO (SOft attribution using FlexparT and carbon monoxide emission inventories for In-situ Observation database) model, which couples back trajectories with CO emission inventories, was used to explore the origins and sources of the tropical CO observed by IAGOS. The highest O3 and CO mixing ratios occur over western Africa in the lower troposphere (LT: surface to 750 hPa) during the fire season (75 ppb of O3 at 2.5 km and 850 ppb of CO at 0.3 km over Lagos in January), mainly due to anthropogenic (AN) emissions and a major contribution from fires. The secondary maxima are observed in Asia in the mid-troposphere (MT: 750–300 hPa) and upper troposphere (UT: 300–200 hPa) in April for O3 and in the LT in January for CO, with larger contributions from AN emissions. The lowest O3 and CO mixing ratios occur over Caracas. In the tropical LT, the majority of the location clusters are affected by local and regional AN emissions. The highest AN impact is found over Asia, Arabia and eastern Africa, and South America (> 75 % of CO). Biomass burning (BB) emissions also originate from local or regional sources but with stronger seasonal dependence. The highest BB impact is found over southern tropical Africa (57 %–90 %), except in April, mostly due to local fires, but also from Northern Hemisphere Africa in January (45 %–73 %) and Southern Hemisphere South America in October (29 % over Windhoek). In the MT and UT, AN emissions are more important and dominate in the eastern part of the tropics (from the Middle East to Asia). BB contributions are more important than in the LT, especially from the African fires in January and July and from South East and equatorial Asia in April and October. The overall highest amount of CO is exported from Africa, with the main transport pathway from the dry- season African regions towards the wet-season ones. In contrast, the impact of the Asian emissions in the LT and MT is limited on a local or regional scale. The transport of polluted Asian air masses is important in the UT during the Asian summer monsoon and post-monsoon seasons, when convection is active
acp-23-14039-2023.pdf (10.82 Mo) Télécharger le fichier
Licence : CC BY - Paternité
insu-04553234 , version 1 (19-04-2024)
Maria Tsivlidou, Bastien Sauvage, Yasmine Bennouna, Romain Blot, Damien Boulanger, et al.. Tropical tropospheric ozone and carbon monoxide distributions: characteristics, origins, and control factors, as seen by IAGOS and IASI. Atmospheric Chemistry and Physics, 2023, 23, pp.14039 - 14063. ⟨10.5194/acp-23-14039-2023⟩. ⟨insu-04553234⟩
0 Consultations
0 Téléchargements
