A solar cycle clock for extreme space weather - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Scientific Reports Year : 2024
The variable solar cycle of activity is a long-standing problem in physics. It modulates the overall level of space weather activity at earth, which in turn can have significant societal impact. The Hilbert transform of the sunspot number is used to map the variable length, approximately 11 year Schwabe cycle onto a uniform clock. The clock is used to correlate extreme space weather seen in the aa index, the longest continuous geomagnetic record at earth, with the record of solar active region areas and latitudes since 1874. This shows that a clear switch-off of the most extreme space weather events occurs when >90 % of solar active region areas have moved to within about 15° of the solar equator, from regions of high gradient in solar differential rotation which can power coronal mass ejections, to a region where solar differential rotation is almost constant with latitude. More moderate space weather events which coincide with 27 day solar rotation recurrences in the aa index, consistent with stable, persistent source regions of high speed streams, commence when the centroid of solar active region areas moves to within 15° of the solar equator. This offers a physical explanation for the longstanding identification of a two component cycle of activity in the aa index.
s41598-024-58960-5.pdf (5.84 Mo) Télécharger le fichier
Origin : Publisher files allowed on an open archive
Dates and versions
insu-04569481 , version 1 (06-05-2024)
Attribution
Identifiers
Cite
S. C. Chapman, Thierry Dudok de Wit. A solar cycle clock for extreme space weather. Scientific Reports, 2024, 14, ⟨10.1038/s41598-024-58960-5⟩. ⟨insu-04569481⟩
0 View
0 Download
Share
