Influence of salinity gradients on the diffusion of water and ionic species in dual porosity clay samples - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Contaminant Hydrology Année : 2024
Most of the available data on diffusion in natural clayey rocks consider tracer diffusion in the absence of a salinity gradient despite the fact that such gradients are frequently found in natural and engineered subsurface environments. To assess the role of such gradients on the diffusion properties of clayey materials, through-diffusion experiments were carried out in the presence and absence of a salinity gradient using salt-diffusion and radioisotope tracer techniques. The experiments were carried out with vermiculite samples that contained equal proportions of interparticle and interlayer porosities so as to assess also the role played by the two types of porosities on the diffusion of water and ions. Data were interpreted using both a classical Fickian diffusion model and with a reactive transport code, CrunchClay that can handle multi-porosity diffusion processes in the presence of charged surfaces. By combining experimental and simulated data, we demonstrated that (i) the flux of water diffusing through vermiculite interlayer porosity was minor compared to that diffusing through the interparticle porosity, and (ii) a model considering at least three types of porous volumes (interlayer, diffuse layer interparticle, and bulk interparticle) was necessary to reproduce consistently the variations of neutral and charged species diffusion as a function of salinity gradient conditions.
Fichier sous embargo
0 5 10
Année Mois Jours
Avant la publication
mercredi 6 novembre 2024
Connectez-vous pour demander l'accès au fichier
insu-04569499 , version 1 (06-05-2024)
insu-04569499 , version 2 (16-05-2024)
Paternité
Emmanuel Tertre, Thomas Dabat, Jingyi Wang, Sébastien Savoye, Fabien Hubert, et al.. Influence of salinity gradients on the diffusion of water and ionic species in dual porosity clay samples. Journal of Contaminant Hydrology, 2024, pp.104357. ⟨10.1016/j.jconhyd.2024.104357⟩. ⟨insu-04569499v1⟩
0 Consultations
0 Téléchargements
