On Rules with Existential Variables: Walking the Decidability Line - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Artificial Intelligence Année : 2011
Jean-François Baget
Michel Leclère
Eric Salvat
  • Fonction : Auteur
  • PersonId : 861157
We consider positive rules in which the conclusion may contain existentially quantified variables, which makes reasoning tasks (such as conjunctive query answering or entailment) undecidable. These rules, called forall-exists-rules, have the same logical form as tuple-generating dependencies in databases and as conceptual graph rules. The aim of this paper is to provide a clearer picture of the frontier between decidability and non-decidability of reasoning with these rules. Previous known decidable classes were based on forward chaining. On one hand we extend these classes, on the other hand we introduce decidable classes based on backward chaining. A side result is the definition of a backward mechanism that takes the complex structure of forall-exists-rule conclusions into account. We classify all known decidable classes by inclusion. Then, we study the question of whether the union of two decidable classes remains decidable and show that the answer is negative, except for one class and a still open case. This highlights the interest of studying interactions between rules. We give a constructive definition of dependencies between rules and widen the landscape of decidable classes with conditions on rule dependencies and a mixed forward/backward chaining mechanism. Finally, we integrate rules with equality and negative constraints to our framework.
lirmm-00587012 , version 1 (19-04-2011)
Jean-François Baget, Michel Leclère, Marie-Laure Mugnier, Eric Salvat. On Rules with Existential Variables: Walking the Decidability Line. Artificial Intelligence, 2011, 175 (9-10), pp.1620-1654. ⟨10.1016/j.artint.2011.03.002⟩. ⟨lirmm-00587012⟩
296 Consultations
0 Téléchargements
