Improving Many-Task Computing in Scientific Workflows Using P2P Techniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Large-scale scientific experiments are usually supported by scientific workflows that may demand high performance computing infrastructure. Within a given experiment, the same workflow may be explored with different sets of parameters. However, the parallelization of the workflow instances is hard to be accomplished mainly due to the heterogeneity of its activities. Many-Task computing paradigm seems to be a candidate approach to support workflow activity parallelism. However, scheduling a huge amount of workflow activities on large clusters may be susceptible to resource failures and overloading. In this paper, we propose Heracles, an approach to apply consolidated P2P techniques to improve Many-Task computing of workflow activities on large clusters. We present a fault tolerance mechanism, a dynamic resource management and a hierarchical organization of computing nodes to handle workflow instances execution properly. We have evaluated Heracles by executing experimental analysis regarding the benefits of P2P techniques on the workflow execution time.
paper07-1.pdf (619.14 Ko) Télécharger le fichier
lirmm-00641008 , version 1 (14-11-2011)
  • HAL Id : lirmm-00641008 , version 1
Jonas Dias, Eduardo Ogasawara, Daniel De Oliveira, Esther Pacitti, Marta Mattoso. Improving Many-Task Computing in Scientific Workflows Using P2P Techniques. MTAGS: Many-Task Computing on Grids and Supercomputers, 2010, New Orleans, United States. pp.31-40. ⟨lirmm-00641008⟩
312 Consultations
433 Téléchargements
