An Uncertain Data Integration System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Naser Ayat
  • Fonction : Auteur
  • PersonId : 932772
Hamideh Afsarmanesh
  • Fonction : Auteur
  • PersonId : 932773
Reza Akbarinia
Patrick Valduriez
Data integration systems off er uniform access to a set of autonomous and heterogeneous data sources. An important task in setting up a data integration system is to match the attributes of the source schemas. In this paper, we propose a data integration system which uses the knowledge implied within functional dependencies for matching the source schemas. We build our system on a probabilistic data model to capture the uncertainty arising during the matching process. Our performance validation con rms the importance of functional dependencies and also using a probabilistic data model in improving the quality of schema matching. Our experimental results show significant performance gain compared to the baseline approaches. They also show that our system scales well.
2012_-_ODBASE_-_An_uncertain_Data_Integration_System.pdf (431.58 Ko) Télécharger le fichier
lirmm-00748621 , version 1 (05-11-2012)
  • HAL Id : lirmm-00748621 , version 1
Naser Ayat, Hamideh Afsarmanesh, Reza Akbarinia, Patrick Valduriez. An Uncertain Data Integration System. ODBASE'2012: 11th International Conference on Ontologies, DataBases, and Applications of Semantics, Sep 2012, Roma, Italy. pp.18. ⟨lirmm-00748621⟩
527 Consultations
508 Téléchargements
