Public Data Integration with WebSmatch - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Integrating open data sources can yield high value information but raises major problems in terms of metadata extraction, data source integration and visualization of integrated data. In this paper, we describe the demonstration of WebSmatch, a flexible environment for Web data integration, based on a real, end-to-end data integration scenario over public data from Data Publica. WebSmatch supports the full process of importing, refining and integrating data sources and uses third party tools for high quality visualization. We use a typical scenario of public data integration which involves problems not solved by currents tools: poorly structured input data sources (XLS files) and rich visualization of integrated data.
1205.2555v2.pdf (938.69 Ko) Télécharger le fichier
lirmm-00750927 , version 1 (12-11-2012)
  • HAL Id : lirmm-00750927 , version 1
Remi Coletta, Emmanuel Castanier, Patrick Valduriez, Christian Frisch, Duy Hoa Ngo, et al.. Public Data Integration with WebSmatch. WOD: Workshop on Open Data, May 2012, Nantes, France. pp.5-12. ⟨lirmm-00750927⟩
402 Consultations
450 Téléchargements
