Appariement d'images par invariants locaux de niveaux de gris. Application à l'indexation d'une base d'objets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 1996
Image matching by local greyvalue invariants. Applied to indexing an object database
This thesis concerns matching, a fundamental subject in computer vision. Matching covers a variety of problems such as matching two images or matching an image with a CAD model. Our approach allows objects to be matched if they are observed in complex scenes, partially occluded or seen from different viewpoints. The method is extended to image database consultation and object recognition. Our approach is based on a local characterization of the greyvalue signal. This characterization is calculated at particular «points of interest». These are detected automatically and are representative of the observed object. Therefore, the characterization obtained has a high information content. In addition, it is invariant to the similarity group of transformations in the image and allows images that have undergone such transformations to be matched. To first order, the similarity group absorbs variations of perspective viewpoint changes, so our representation is quasi-invariant and therefore robust to such transformations. The method has been applied to the retrieval of images from a large database. When there are many images there are typically many possible matches for any given point, so a robust statistical technique has been developed to find the corresponding image. To reduce the amount of computation required for a large database and make rapid retrieval possible, an indexing mechanism has been developed. Our image retrieval scheme has been applied to 3D object recognition from a single image. Each object is modeled by a set of images taken from different viewpoints chosen to be representative of the object. To obtain 3D information, the different aspects of the objects stored in the database are annotated with symbolic data. The trilinearity constraint allows this data to be localized in the image.
Cette thèse s'inscrit dans le domaine de l'appariement, un sujet fondamental en vision par ordinateur. Ce domaine recouvre des problèmes variés allant de celui de l'appariement entre deux images à celui de l'appariement d'une image et un modèle CAO. Notre approche permet d'apparier des objets s'ils sont observés dans des scènes complexes, s'ils sont partiellement visibles et s'ils sont aperçus de points de vue différents. Cette méthode est étendue à l'interrogation de bases d'images et à la reconnaissance d'objets. Notre approche est basée sur une caractérisation locale des niveaux de gris d'une image. Cette caractérisation est calculée en des points particuliers des images : les points d'intérêt. Ces points sont détectés automatiquement et sont représentatifs de l'objet observé. De ce fait, la caractérisation obtenue représente une information très riche. De plus, elle est invariante pour le groupe des similitudes image et permet d'apparier des images ayant subi de telles transformations. Comme le groupe des similitudes absorbe au premier ordre les variations dues à un changement de point de vue lors d'une projection perspective, notre représentation est quasi-invariante et donc robuste à une telle transformation. La solution présentée a été appliquée à la recherche d'une image dans une volumineuse base d'images. Comme la multiplicité des correspondances ne permet plus d'avoir directement de réponse satisfaisante, une méthode statistiquement robuste fait émerger la solution. D'autre part, pour effectuer une recherche rapide dans une large base un mécanisme d'indexation a été développé. La recherche d'image a été étendue à la reconnaissance d'objet à partir d'une seule image. Pour ce faire, un objet 3D est modélisé par une collection d'images représentatives de l'objet. Pour obtenir une information 3D, des données symboliques sont ajoutées aux différents aspects de l'objet stockés dans la base. La relation trilinéaire permet alors de retrouver ces données sur une image recherchée.
tel-00005019.pdf (2.26 Mo) Télécharger le fichier
tel-00005019 , version 1 (23-02-2004)
  • HAL Id : tel-00005019 , version 1
Cordelia Schmid. Appariement d'images par invariants locaux de niveaux de gris. Application à l'indexation d'une base d'objets. Interface homme-machine [cs.HC]. Institut National Polytechnique de Grenoble - INPG, 1996. Français. ⟨NNT : ⟩. ⟨tel-00005019⟩
844 Consultations
1453 Téléchargements
