Human Posture Recognition for Behaviour - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2007
Reconnaissance de postures pour l'interprétation d'activité humaine
During this thesis, we have proposed a real-time, generic, and operational approach to recognising human posture with one static camera. The approach is fully automatic and independent from the view point of the camera. Human posture recognition from a video sequence is a difficult task. This task is part of the more general problem of video sequence interpretation. The proposed approach takes as input information provided by vision algorithms such as the silhouette of the observed person (a binary image representing the person and the background), or her/his position in the scene. The first contribution is the modeling of a 3D posture avatar. This avatar is composed of a human model (defining the relations between the different body parts), a set of parameters (defining the position of the body parts) and a set of body primitives (defining the visual aspect of the body parts). The second contribution is the proposed hybrid approach to recognise human posture. This approach combines the use of 3D posture avatar and 2D techniques. The 3D avatars are used in the recognition process to acquire a certain independence from the camera view point. The 2D techniques represent the silhouettes of the observed person to provide a real-time processing. The proposed approach is composed of two main parts: the posture detection which recognises the posture of the detected person by using information computed on the studied frame, and the posture temporal filtering which filters the posture by using information about the posture of the person on the previous frames A third contribution is the comparison of different 2D silhouette representations. The comparison is made in terms of computation time and dependence on the silhouette quality. Four representations have been chosen: geometric features, Hu moments, skeletonisation, and the horizontal and vertical projections. A fourth contribution is the characterisation of ambiguous postures. Ambiguities can happen by using only one camera. An ambiguous posture is defined as a posture which has visually similar silhouettes rather an other posture. Synthetic data are generated to evaluate the proposed approach for different point of view. The approach has also been evaluated on real data by proposing a ground truth model adapted to the posture recognition purpose. A fifth contribution has been proposed by applying the results of the recognition to human action detection. A method based on a finite state machine has been proposed to recognise self-action (action where only one person acts). Each state v of the machine is composed of one or several postures. This method has been successfully applied to detect falling and walking actions. The human posture recognition approach gives good results. However, the approach has some limitation. The main limitation, is that we are limited in terms of postures of interest for computation time and discrimination reasons. The second limitation is the computation time of the 3D posture avatar generation. By using information about the movement of the observed person in the scene, the approach is able to treat 5-6 frames by second. Some improvement can be done to solve these limitations. In particular, the set of interest postures can be adapted automatically at each frame by considering the previously recognised postures to decrease the number of 3D posture silhouette to extract.
Durant cette thèse nous avons proposé une approche temps réel, générique et fonctionnelle pour reconnaître la posture des personnes filmées par une caméra statique. Notre approche est conçue pour être complètement automatique et indépendante du point de vue de la caméra. La reconnaissance de posture à partir de séquence vidéo est un problème difficile. Ce problème s'inscrit dans le champ de recherche plus général de l'interprétation de séquence vidéo. L'approche proposée prend en entrée des informations provenant d'algorithmes de vision telles que la silhouette de la personne observée (une image binaire où une couleur représente la personne et l'autre le fond) ou sa position dans la scène. La première contribution est la modélisation d'un avatar 3D de posture. Un avatar 3D de posture est composé d'un modèle 3D humain (définissant les relations entre les différentes parties du corps), d'un ensemble de paramètre (définissant les positions des différentes parties du corps) et d'un ensemble de primitive (définissant l'aspect visuel des parties du corps). La seconde contribution est la proposition d'une approche hybride combinant l'utilisation de modèles 3D et de techniques 2D. Les avatars 3D de postures sont utilisés dans le processus de reconnaissance pour avoir une certaine indépendance du point de vue de la caméra. Les techniques 2D représentent les silhouettes des personnes détectées pour garder un temps réel de calcul. Cette thèse montre comment les avatars 3D peuvent être utilisés pour obtenir une approche générique et fonctionnelle pour reconnaître les postures. Cette approche est composée de deux parties : la détection de postures qui reconnaît la posture de la personne détectée en utilisant seulement l'information calculée sur l'image considérée, et le filtrage temporel de posture qui reconnaît la posture en utilisant l'information provenant des images précédentes. Une troisième contribution a été faite en comparant différentes représentations 2D des silhouettes au niveau du temps de calcul nécessaire et de leur dépendance à la qualité de la silhouette. Quatre représentations ont été retenues : une représentation combinant différentes valeurs géométriques, les moment de Hu, la skeletonisation et les projections horizontale et verticale. Une quatrième contribution est la caractérisation des cas ambigus. Des ambiguïtés au niveau de la reconnaissance peuvent se produire en utilisant seulement une caméra statique. Une posture ambiguë est définie par plusieurs postures vii qui ont des silhouettes visuellement similaires. Des données de synthèse sont générées pour évaluer l'approche proposée pour différents points de vue. Ainsi, les postures ambiguës sont identifiées en considérant la posture et son orientation. L'approche est aussi évaluée pour des données réelles en proposant un modèle de vérité terrain pour la reconnaissance de posture. Une cinquième contribution a été proposée en appliquant le résultat de notre approche à la reconnaissance d'action. Une méthode utilisant des machines à états finis a ainsi été proposée pour reconnaître des actions faisant intervenir une seule personne. Chaque état de la machine est composé d'une ou plusieurs postures. Cette méthode est appliquée avec succès pour détecter les chutes et la marche. Bien que notre approche donne de très bon taux de reconnaissance, il subsiste quelques limitations. La principale limitation de l'approche est qu'elle est limitée en nombre de postures d'intérêt pour des raisons de temps de calcul et de discrimination entre les postures considérées. La seconde limitation est le temps nécessaire à la génération des silhouettes des avatars 3D de posture. En utilisant l'information sur le déplacement de la personne dans la scène, l'algorithme de reconnaissance de posture traite entre 5 et 6 images par seconde. Des améliorations peuvent être faites pour résoudre ces limitations. En particulier, nous pourrions adapter automatiquement l'ensemble des postures d'intérêt au cas considéré, en utilisant par exemple la posture reconnue précédemment pour restreindre les postures 3D dont nous voulons extraire les silhouettes.
Boulay-PhD.pdf (3.42 Mo) Télécharger le fichier
tel-00311741 , version 1 (20-08-2008)
  • HAL Id : tel-00311741 , version 1
Bernard Boulay. Human Posture Recognition for Behaviour. Other [cs.OH]. Université Nice Sophia Antipolis, 2007. English. ⟨NNT : ⟩. ⟨tel-00311741⟩
Collections
INRIA INRIA2
518 Consultations
2751 Téléchargements
