Mécanismes numériques et distribués de l'anticipation motrice - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2008
Numerical and distributed mechanisms of motor anticipation
Jérémy Fix
This thesis belongs to the computational neuroscience domain in which we aim at understanding complex cognitive functions with computer simulations built on the current knowledge of the brain. The proposed models and simulations are built on the paradigm of dynamic neural fields, that we use in order to study in which way complex congitive capabilities can be the emergent result of the interaction of elementary units.
In this thesis, we are interested in the modelisation of visual attention, with and without eye movements. To guide the development of these models, we propose in the first part a review of the current psychological and physiological data on visual attention, before proposing a computational model of visual attention without saccadic eye movement. Then, we study in the second part the way we can integrate saccadic eye movements in our models based on the current anatomical and physiological data on the oculomotor control in the primate. The performances of the different proposed mechanisms are evaluated by simulating visual search tasks with saccadic eye movements.
This work also makes us able to study a computational paradigm that relies on distributed, asynchronous, numerical and adaptive computation which permits to consider further developments of the proposed mechanisms on parallel architectures.
Cette thèse s'inscrit dans le domaine des neurosciences computationnelles dont le but est de modéliser des fonctions cognitives complexes par le biais de simulations informatiques et numériques en s'inspirant du fonctionnement cérébral. Les modèles et simulations proposées reposent sur le paradigme des champs neuronaux, que nous exploitons pour étudier dans quelle mesure des capacités cognitives complexes peuvent être le résultat émergeant de l'interaction de cellules élémentaires simples.
Nous nous intéressons dans cette thèse à la modélisation de l'attention visuelle, avec ou sans mouvement oculaire. Pour guider le développement de nos modèles, nous proposons dans une première partie une revue de données psychologiques et physiologiques sur l'attention visuelle avant de proposer un modèle computationnel de l'attention visuelle sans saccade oculaire. Puis, nous nous intéressons dans une seconde partie à la manière dont on peut intégrer les saccades oculaires dans nos modèles en s'inspirant des données anatomiques et physiologiques sur le contrôle des saccades oculaires chez le primate. Les performances des différents mécanismes proposés sont évalués en simulation en les appliquant à des tâches de recherche visuelle.
Nos travaux de thèse permettent également d'étudier un paradigme de calcul original qui repose sur des calculs distribués, asynchrones, numériques et adaptatifs qui permettent d'envisager le déploiement des mécanismes proposés dans ce cadre sur des supports de calculs parallèles.
Manuscrit.pdf (6.37 Mo) Télécharger le fichier
Soutenance.pdf (6.53 Mo) Télécharger le fichier
Format : Autre
tel-00336194 , version 1 (03-11-2008)
tel-00336194 , version 2 (03-11-2008)
tel-00336194 , version 3 (18-11-2008)
  • HAL Id : tel-00336194 , version 2
Jérémy Fix. Mécanismes numériques et distribués de l'anticipation motrice. Modélisation et simulation. Université Henri Poincaré - Nancy I, 2008. Français. ⟨NNT : ⟩. ⟨tel-00336194v2⟩
323 Consultations
522 Téléchargements
