L'IMAGERIE POST MORTEM TRIDIMENSIONNELLE CEREBRALE : CONSTITUTION ET APPORT POUR L'ANALYSE CONJOINTE DE DONNEES HISTOLOGIQUES ANATOMO-FONCTIONNELLES ET LA MISE EN CORRESPONDANCE AVEC L'IMAGERIE IN VIVO. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2005
Cerebral three-dimensional Post Mortem Imaging : constitution and contribution for the joint analysis of anatomo-functional histological data and matching with in vivo imaging.
The 3D reconstruction of histological slices yields a new modality that we call Post Mortem Imaging (PMI). In this thesis, we propose a classification for brain histology studies, and we describe two protocols for the constitution of cerebral PMI. The first protocol deals with animals such as rodents. It includes the acquisition and the extraction of anatomical (stained histological slices) and functional (autoradiographies) series. This step is followed by the alignment and the coalignment of the histological slices to constitute anatomical and functional volumes that are spatially consistent and registered, allowing the performance of 3D analysis. The second protocol deals with animals such as primates. It describes a complete method for matching in vivo and post mortem data. A volume of histological slices is obtained by coalignement with block face photographs taken of the brain during the cutting process. Furthermore, a robust inter-slice intensity normalisation is proposed to recover intensity 3D consistency. Finally, an elastic deformation is estimated between the post mortem brain and the brain in its in vivo geometry (embodied by the MRI data) to correct for volume differences related to histology. As direct applications of this protocol, we present the creation of atlases of the thalamus, which are compared to an in vivo segmentation of the thalamus realized on diffusion MRI data using a new method based on classification mechanisms. We conclude this work through the utilisation of PMI and its prospects for the future.
La reconstruction 3D de coupes histologiques donne lieu à une nouvelle modalité tridimensionnelle que nous désignons par Imagerie Post Mortem ou IPM. Après avoir proposé une classification des études mettant en jeu l'histologie et concernant le cerveau, nous décrivons dans ce travail de thèse deux protocoles de constitution d'IPM cérébrale. Le premier protocole concerne les animaux de type rongeurs. Il comprend l'acquisition et l'extraction en séries de données anatomiques (coupes histologiques marquées) et fonctionnelles (coupes autoradiographiques). Ces étapes sont suivies de l'alignement et du coalignement des coupes histologiques pour constituer un volume anatomique et un volume fonctionnel spatialement cohérents et recal és entre eux, permettant de mener des analyses 3D. Le deuxième protocole concerne les animaux de type primates. Il décrit une méthode complète de mise en correspondance d'images in vivo et post mortem. Un volume de coupes histologiques est obtenu par coalignement avec des photographies prises lors de la coupe. Une normalisation d'intensité inter-coupes robuste est proposée pour rendre également cohérent tridimensionnellement en intensité ce volume. Enfin, une déformation élastique est estimée entre le cerveau post mortem et le cerveau dans sa géométrie in vivo (représenté par l'IRM) pour corriger les différences de volume inhérentes à l'histologie. La réalisation d'atlas du thalamus, puis une confrontation avec une segmentation réalisée in vivo en IRM de diffusion par une nouvelle méthode par classification sont présentées comme applications directes de ce protocole. Nous concluons ce travail par diverses perspectives d'utilisation de l'IPM.
dauguet-phd-2005b.pdf (6.28 Mo) Télécharger le fichier
tel-00339418 , version 1 (17-11-2008)
  • HAL Id : tel-00339418 , version 1
Julien C. Dauguet. L'IMAGERIE POST MORTEM TRIDIMENSIONNELLE CEREBRALE : CONSTITUTION ET APPORT POUR L'ANALYSE CONJOINTE DE DONNEES HISTOLOGIQUES ANATOMO-FONCTIONNELLES ET LA MISE EN CORRESPONDANCE AVEC L'IMAGERIE IN VIVO.. Interface homme-machine [cs.HC]. Ecole Centrale Paris, 2005. Français. ⟨NNT : ⟩. ⟨tel-00339418⟩
Collections
CEA
384 Consultations
1111 Téléchargements
