Finding People in Images and Videos - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2006
Navneet Dalal
  • Fonction : Auteur
  • PersonId : 860809
This thesis targets the detection of humans and other object classes in images and videos. Our focus is on developing robust feature extraction algorithms that encode image regions as highdimensional feature vectors that support high accuracy object/non-object decisions. To test our feature sets we adopt a relatively simple learning framework that uses linear Support Vector Machines to classify each possible image region as an object or as a non-object. The approach is data-driven and purely bottom-up using low-level appearance and motion vectors to detect objects. As a test case we focus on person detection as people are one of the most challenging object classes with many applications, for example in film and video analysis, pedestrian detection for smart cars and video surveillance. Nevertheless we do not make any strong class specific assumptions and the resulting object detection framework also gives state-of-the-art performance for many other classes including cars, motorbikes, cows and sheep. This thesis makes four main contributions. Firstly, we introduce grids of locally normalised Histograms of Oriented Gradients (HOG) as descriptors for object detection in static images. The HOG descriptors are computed over dense and overlapping grids of spatial blocks, with image gradient orientation features extracted at fixed resolution and gathered into a highdimensional feature vector. They are designed to be robust to small changes in image contour locations and directions, and significant changes in image illumination and colour, while remaining highly discriminative for overall visual form. We show that unsmoothed gradients, fine orientation voting, moderately coarse spatial binning, strong normalisation and overlapping blocks are all needed for good performance. Secondly, to detect moving humans in videos, we propose descriptors based on oriented histograms of differential optical flow. These are similar to static HOG descriptors, but instead of image gradients, they are based on local differentials of dense optical flow. They encode the noisy optical flow estimates into robust feature vectors in a manner that is robust to the overall camera motion. Several variants are proposed, some capturing motion boundaries while others encode the relative motions of adjacent image regions. Thirdly, we propose a general method based on kernel density estimation for fusing multiple overlapping detections, that takes into account the number of detections, their confidence scores and the scales of the detections. Lastly, we present work in progress on a parts based approach to person detection that first detects local body parts like heads, torso, and legs and then fuses them to create a global overall person detector.
Cette thèse propose une solution pour la détection de personnes et de classes d'objet dans des images et vidéos. Le but principal est de développer des représentations robustes et discriminantes de formes visuelles, qui permettent de décider si un objet de la classe apparaˆit dans une région de l'image. Les décisions sont basées sur des vecteurs de descripteurs visuels de dimension élevée extraits des régions. Afin d'avoir une comparaison objective des différents ensembles de descripteurs, nous apprenons une règle de décision pour chaque ensemble avec un algorithme de type machine à vecteur de support linéaire. Piloté entièrement par les données, notre approche se base sur des descripteurs d'apparence et de mouvement de bas niveau sans utiliser de modèle explicite pour l'objet a détecter. Dans la plupart des cas nous nous concentrons sur la détection de personnes – classe difficile, fréquente et particulièrement intéressante dans applications come l'analyse de film et de vidéo, la détection de piétons pour la conduite assistée ou la surveillance. Cependant, notre méthode ne fait pas d'hypothèse forte sur la classe à reconnaˆitre et elle donne également des résultats satisfaisants pour d'autres classes comme les voitures, les motocyclettes, les vaches et les moutons. Nous apportons quatre contributions principales au domaine de la reconnaissance visuelle. D'abord, nous présentons des descripteurs visuels pour la détection d'objets dans les images statiques : les grilles d'histogrammes d'orientations de gradients d'image (en anglais, HOG – Histogrammes of Oriented Gradients). Les histogrammes sont évalués sur une grille de blocs spatiaux, avec une forte normalisation locale. Cette structure assure à la fois une bonne caract érisation de la forme visuelle locale de l'objet et la robustesse aux petites variations de position, d'orientation spatiale, d'illumination locale et de couleur. Nous montrons que la combinaison de gradients peu lissés, une quantification fine de l'orientation et relativement grossière de l'espace, une normalisation forte de l'intensité, et une méthode évoluée de ré-apprentissage des cas difficiles permet de réduire le taux de faux positifs par un à deux ordres de grandeur par rapport aux méthodes précédentes. Deuxièmement, afin de détecter des personnes dans les vidéos, nous proposons plusieurs descripteurs de mouvement basés sur le flot optique. Ces descripteurs sont incorporés dans l'approche précédente. Analogues aux HOG statiques, ils substituent aux gradients d'image statique les différences spatiales du flot optique dense. L'utilisation de différences minimise l'influence du mouvement de la caméra et du fond sur les détections. Nous évaluons plusieurs variations de cette approche, qui codent soit les frontières de mouvement (motion boundaries), soit les mouvements relatifs des paires de régions adjacentes. L'incorporation du mouvement réduit le taux de faux positifs d'un ordre de grandeur par rapport à l'approche précédente. Troisièmement, nous proposons une méthode générale pour combiner les détections multiples basées sur l'algorithme “mean shift” pour estimer des maxima de densité à base de noyaux. L'approche tient compte du nombre, de la confiance et de l'échelle relative des détections. Finalement, nous présentons un travail en cours sur la fac¸on de créer de un détecteur de personnes à partir de plusieurs détecteurs de parties – en occurrence le visage, la tête, le torse, et les jambes.
NavneetDalalThesis.pdf (6.5 Mo) Télécharger le fichier
tel-00390303 , version 1 (01-06-2009)
  • HAL Id : tel-00390303 , version 1
Navneet Dalal. Finding People in Images and Videos. Human-Computer Interaction [cs.HC]. Institut National Polytechnique de Grenoble - INPG, 2006. English. ⟨NNT : ⟩. ⟨tel-00390303⟩
2351 Consultations
7672 Téléchargements
