Analyses formelle et relationnelle de concepts pour la construction d'ontologies de domaines à partir de ressources textuelles hétérogènes - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Theses Year : 2009
Rokia Bendaoud
  • Function : Author
  • PersonId : 830684
Ontologies are used in different fields like the semantic Web or the knowledge engineering. Ontologies allow to share, to diffuse and to update knowledge domain. This thesis proposes a methodology to build ontologies using methods of Natural Language Processing (NLP) and Information Extraction (IE) for extracting prepared data from each kind of available resources in the domain (text corpora, databases, thesaurus). Then, these prepared data are mining two mining methods : Formal Concept Analysis (FCA) and Relational Concept Analysis (RCA). The FCA regroups a set of objects sharing the same set of attributes in the same concept. The RCA, an extension of the FCA regroups a set of objects sharing the same attributes and the same relations (relational attributes) in the same concept. The apposition of contexts, a property of the FCA, affects a set of attributes and relational attributes to classes pre-defined and hierarchised by the domain experts. These affectations allow us to present classes and their definitions to the experts of domain as well as new nonexistent classes in the initial hierarchy. These new classes can be considered appropriate and added by experts as new "knowledge units". The Lattices resulting from the data mining methods are considered as « ontology schema ». This ontology schema is represented in the FLE description logics language to obtain ontology. This ontology, is implemented in the OWL, allows us to request it. This methodology was tested in different domains: Microbiology and Astronomy.
Les ontologies sont diversement employées notamment dans les domaines du Web sémantique, de l'ingénierie des connaissances,... En effet, elles permettent de partager, de diffuser et d'actualiser les connaissances d'un domaine. Afin de construire ces ontologies, notre méthodologie utilise tout d'abord des méthodes de Traitement Automatique de la Langue Naturelle (TALN) et d'Extraction d'Information (EI) pour extraire des données préparées à partir de chaque ressource du domaine (corpus de textes, bases de données, thesaurus). Puis, ces données sont fouillées avec les méthodes de fouilles : l'Analyse Formelle de concepts (AFC) et l'Analyse Relationnelle de Concepts (ARC). L'AFC regroupe des objets partageant les mêmes attributs dans des concepts d'un treillis. L'ARC, une extension de l'AFC, permet de regrouper des objets partageant les mêmes attributs, mais aussi les mêmes attributs relationnels. L'apposition de contextes (une propriété de l'AFC) permet d'associer ces attributs et relations à un ensemble de classes prédéfinies et hiérarchisées par les experts du domaine. De cette façon, des définitions étendues sont proposées aux experts du domaine pour ces classes prédéfinies ainsi que de nouvelles classes inexistantes dans la hiérarchie initiale. Ces nouvelles classes peuvent être considérées pertinentes et ajoutées par les experts en tant que nouvelles "unités de connaissances". Les treillis résultant des méthodes de fouille constituent ce que nous appelons schéma d'ontologie. Ce schéma d'ontologie est ensuite représenté par le langage FLE de la famille des logiques de descriptions afin d'avoir une ontologie. Cette ontologie, implémentée en OWL, a permis à notre système de répondre automatiquement à différentes questions proposées par les experts du domaine.
Des expériences pratiques ont été menées dans deux domaines d'application : l'astronomie et la microbiologie.
BendaoudThese.pdf (5.78 Mo) Télécharger le fichier
Dates and versions
tel-00420109 , version 1 (28-09-2009)
Identifiers
  • HAL Id : tel-00420109 , version 1
Cite
Rokia Bendaoud. Analyses formelle et relationnelle de concepts pour la construction d'ontologies de domaines à partir de ressources textuelles hétérogènes. Interface homme-machine [cs.HC]. Université Henri Poincaré - Nancy I, 2009. Français. ⟨NNT : ⟩. ⟨tel-00420109⟩
447 View
206 Download
Share
Gmail Mastodon Facebook X LinkedIn More
