Assimilation d'images pour les fluides géophysiques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2010
Image assimilation for geophysical fluids
Understanding and forecasting the evolution of geophysical fluids is a major scientific and societal challenge. A good forecast must take into account all available information on the studied system. These informations include models, observations and a priori knowledge. Data assimilation techniques combine all these informations in a consistent way to produce model inputs. During the last decades, many satellites were launched to increase the knowledge of earth. They produce, among others, image sequences showing the dynamical evolution of geophysical processes such as depressions and fronts. These images sequences are currently under-utilized in data assimilation. This thesis presents a consistent approach for taking into account image sequences in variational data assimilation. After a presentation of images, their current use and its limitation, we introduce the concepts of interpretation level, image space and image operator used for direct image sequences assimilation. We also propose a new approach of regularization based on generalized diffusion for ill-posed inverse problems. Preliminary results on image processing and image sequences assimilation show a promising approach that solve most of the problems encountered with classical approaches of regularization.
La compréhension et la prévision de l'évolution des fluides géophysiques sont d'une importance capitale et constituent un domaine de recherche scientifique aux enjeux conséquents. Une bonne prévision est basée sur la prise en compte de toutes les informations disponibles sur le système considéré. Ces informations incluent les modèles, les observations et les connaissances a priori. L'assimilation de données permet de les combiner de façon optimale pour déterminer les entrées du modèle. Les dernières décennies ont vu croître en densité et en qualité la couverture satellitaire produisant, entre autres, des séquences d'images montrant l'évolution dynamique de certains phénomènes géophysiques tels que les dépressions et les fronts. Ces séquences d'images sont jusqu'à présent sous-utilisées en assimilation de données. Cette thèse propose une extension de l'assimilation variationnelle de données aux observations de type séquence d'images. Après avoir présenté les images, leur utilisation actuelle et ses limites, nous introduisons les notions de niveau d'interprétation, d'espaces et d'opérateur image. Ces notions sont utilisées pour formuler l'assimilation directe de séquences d'images. Nous proposons également une nouvelle approche de régularisation par diffusion généralisée pour les problèmes inverses. Les résultats préliminaires en traitement d'images et en assimilation directe de séquence d'images montrent une méthode prometteuse qui résout la plupart des problèmes rencontrés avec les approches classiques de régularisation.
manuscrit_Souopgui.pdf (6.17 Mo) Télécharger le fichier
slides_soutenance.pdf (14.25 Mo) Télécharger le fichier
Format : Autre
tel-00539626 , version 1 (24-11-2010)
  • HAL Id : tel-00539626 , version 1
Innocent Souopgui. Assimilation d'images pour les fluides géophysiques. Mathématiques [math]. Université Joseph-Fourier - Grenoble I, 2010. Français. ⟨NNT : ⟩. ⟨tel-00539626⟩
436 Consultations
564 Téléchargements
