Données multimodales pour l'analyse d'image - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2010
Exploiting Multimodal Data for Image Understanding
Matthieu Guillaumin
  • Fonction : Auteur
  • PersonId : 879978
This dissertation delves into the use of textual metadata for image understanding. We seek to exploit this additional textual information as weak supervision to improve the learning of recognition models. There is a recent and growing interest for methods that exploit such data because they can potentially alleviate the need for manual annotation, which is a costly and time-consuming process. We focus on two types of visual data with associated textual information. First, we exploit news images that come with descriptive captions to address several face related tasks, including face verification, which is the task of deciding whether two images depict the same individual, and face naming, the problem of associating faces in a data set to their correct names. Second, we consider data consisting of images with user tags. We explore models for automatically predicting tags for new images, i.e. image auto-annotation, which can also used for keyword-based image search. We also study a multimodal semi-supervised learning scenario for image categorisation. In this setting, the tags are assumed to be present in both labelled and unlabelled training data, while they are absent from the test data. Our work builds on the observation that most of these tasks can be solved if perfectly adequate similarity measures are used. We therefore introduce novel approaches that involve metric learning, nearest neighbour models and graph-based methods to learn, from the visual and textual data, task-specific similarities. For faces, our similarities focus on the identities of the individuals while, for images, they address more general semantic visual concepts. Experimentally, our approaches achieve stateof- the-art results on several standard and challenging data sets. On both types of data, we clearly show that learning using additional textual information improves the performance of visual recognition systems.
La présente thèse s'intéresse à l'utilisation de méta-données textuelles pour l'analyse d'image. Nous cherchons à utiliser ces informations additionelles comme supervision faible pour l'apprentissage de modèles de reconnaissance visuelle. Nous avons observé un récent et grandissant intérêt pour les méthodes capables d'exploiter ce type de données car celles-ci peuvent potentiellement supprimer le besoin d'annotations manuelles, qui sont coûteuses en temps et en ressources. Nous concentrons nos efforts sur deux types de données visuelles associées à des informations textuelles. Tout d'abord, nous utilisons des images de dépêches qui sont accompagnées de légendes descriptives pour s'attaquer à plusieurs problèmes liés à la reconnaissance de visages. Parmi ces problèmes, la vérification de visages est la tâche consistant à décider si deux images représentent la même personne, et le nommage de visages cherche à associer les visages d'une base de données à leur noms corrects. Ensuite, nous explorons des modèles pour prédire automatiquement les labels pertinents pour des images, un problème connu sous le nom d'annotation automatique d'image. Ces modèles peuvent aussi être utilisés pour effectuer des recherches d'images à partir de mots-clés. Nous étudions enfin un scénario d'apprentissage multimodal semi-supervisé pour la catégorisation d'image. Dans ce cadre de travail, les labels sont supposés présents pour les données d'apprentissage, qu'elles soient manuellement annotées ou non, et absentes des données de test. Nos travaux se basent sur l'observation que la plupart de ces problèmes peuvent être résolus si des mesures de similarité parfaitement adaptées sont utilisées. Nous proposons donc de nouvelles approches qui combinent apprentissage de distance, modèles par plus proches voisins et méthodes par graphes pour apprendre, à partir de données visuelles et textuelles, des similarités visuelles spécifiques à chaque problème. Dans le cas des visages, nos similarités se concentrent sur l'identité des individus tandis que, pour les images, elles concernent des concepts sémantiques plus généraux. Expérimentalement, nos approches obtiennent des performances à l'état de l'art sur plusieurs bases de données complexes. Pour les deux types de données considérés, nous montrons clairement que l'apprentissage bénéficie de l'information textuelle supplémentaire résultant en l'amélioration de la performance des systèmes de reconnaissance visuelle.
ThesisGuillaumin.pdf (11.48 Mo) Télécharger le fichier
slides.pdf (4 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
tel-00541354 , version 1 (30-11-2010)
tel-00541354 , version 2 (09-05-2011)
  • HAL Id : tel-00541354 , version 2
Matthieu Guillaumin. Données multimodales pour l'analyse d'image. Human-Computer Interaction [cs.HC]. Institut National Polytechnique de Grenoble - INPG, 2010. English. ⟨NNT : ⟩. ⟨tel-00541354v2⟩
1488 Consultations
2097 Téléchargements
