Synthetic 3D Model-Based Object Class Detection and Pose Estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2010
Détection de Classes d'Objets et Estimation de leurs Poses à partir de Modèles 3D Synthétiques
Joerg Liebelt
  • Fonction : Auteur
  • PersonId : 888402
This dissertation aims at extending object class detection and pose estimation tasks on single 2D images by a 3D model-based approach. The work describes learning, detection and estimation steps adapted to the use of synthetically rendered data with known 3D geometry. Most existing approaches recognize object classes for a particular viewpoint or combine classifiers for a few discrete views. By using existing CAD models and rendering techniques from the domain of computer graphics which are parameterized to reproduce some variations commonly found in real images, we propose instead to build 3D representations of object classes which allow to handle viewpoint changes and intra-class variability. These 3D representations are derived in two different ways : either as an unsupervised filtering process of pose and class discriminant local features on purely synthetic training data, or as a part model which discriminatively learns the object class appearance from an annotated database of real images and builds a generative representation of 3D geometry from a database of synthetic CAD models. During detection, we introduce a 3D voting scheme which reinforces geometric coherence by means of a robust pose estimation, and we propose an alternative probabilistic pose estimation method which evaluates the likelihood of groups of 2D part detections with respect to a full 3D geometry. Both detection methods yield approximate 3D bounding boxes in addition to 2D localizations ; these initializations are subsequently improved by a registration scheme aligning arbitrary 3D models to optical and Synthetic Aperture Radar (SAR) images in order to disambiguate and prune 2D detections and to handle occlusions. The work is evaluated on several standard benchmark datasets and it is shown to achieve state-of-the-art performance for 2D detection in addition to providing 3D pose estimations from single images.
Cette thèse porte sur la détection de classes d'objets et l'estimation de leur poses à partir d'une seule image en utilisant des étapes d'apprentissage, de détection et d'estimation adaptées aux données synthétiques. Nous proposons de créer des représentations en 3D de classes d'objets permettant de gérer simultanément des points de vue différents et la variabilité intra-classe. Deux méthodes différentes sont proposées : La première utilise des données d'entraînement purement synthétiques alors que la seconde approche est basée sur un modèle de parties combinant des images d'entraînement réelles avec des données géométriques synthétiques. Pour l'entraînement de la méthode purement synthétique, nous proposons une procédure non-supervisée de filtrage de descripteurs locaux afin de rendre les descripteurs discriminatifs pour leur pose et leur classe d'objet. Dans le cadre du modèle de parties, l'apparence d'une classe d'objets est apprise de manière discriminative à partir d'une base de données annotée et la géométrie en 3D est apprise de manière générative à partir d'une base de modèles CAO. Pendant la détection, nous introduisons d'abord une méthode de vote en 3D qui renforce la cohérence géométrique en se servant d'une estimation robuste de la pose. Ensuite, nous décrivons une deuxième méthode d'estimation de pose qui permet d'évaluer la probabilité de constellations de parties détectées en 2D en utilisant une géométrie 3D entière. Les estimations approximatives sont ensuite améliorées en se servant d'un alignement de modèles 3D CAO avec des images en 2D ce qui permet de résoudre des ambiguïtés et de gérer des occultations.
thesis.pdf (11.31 Mo) Télécharger le fichier
tel-00553343 , version 1 (07-01-2011)
  • HAL Id : tel-00553343 , version 1
Joerg Liebelt. Synthetic 3D Model-Based Object Class Detection and Pose Estimation. Human-Computer Interaction [cs.HC]. Institut National Polytechnique de Grenoble - INPG, 2010. English. ⟨NNT : ⟩. ⟨tel-00553343⟩
621 Consultations
1303 Téléchargements
