Distributed neural computation for the visual perception of motion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2011
Calcul neuronal distribué pour la perception visuelle du mouvement
Mauricio Cerda
  • Fonction : Auteur
  • PersonId : 914225
The work presented in this thesis proposes computational models for motion extraction and pattern recognition from the visual flow of information in the brain and determine how the two tasks can be understood together. More precisely, we propose hypotheses about how the brain mechanism for these tasks may work and we seek to show how neurons with a small receptive field are able to deliver coherent answers and encode complex patterns. We study each aspect of brain processing that we have modelled in a connectionist framework, showing how such distributed systems can be used in complex tasks such as motion detection and pattern recognition. From the computer science perspective, these models provide new algorithms, with interesting properties such as distributed memory utilization and robustness. We have focused our work on two aspects of visual information processing: the detection of motion and the discrimination of complex visual patterns from that signal (or "cognitive vision") that constitute the two parts in which this work is divided. The first part of this thesis about motion detection studies how feature extraction is performed from the visual flow of information, specifically how problems due to the small size and range of the local motion detectors can be solved. In the second part, we work on how the classification of complex visual patterns is achieved from the processing provided by the early vision system, evaluating different feature-extraction techniques to perform what we call cognitive vision.
Le travail présenté dans cette thèse propose des modèles de calcul pour l'extraction du mouvement et la reconnaissance de formes dynamiques à partir du flux d'informations visuelles, en s'inspirant des mécanismes correspondants mis en jeu dans le cerveau. Plus précisément, nous proposons des hypothèses sur la façon dont le mécanisme cérébral de ces tâches peut fonctionner et nous nous efforçons de déterminer comment des neurones avec un petit champ récepteur sont en mesure de fournir des réponses cohérentes et de coder des formes dynamiques complexes. Nous étudions chaque aspect du traitement réalisé dans le cerveau que nous avons modélisé dans un cadre connexionniste, en montrant comment ces systèmes distribués peuvent être utilisés pour des tâches complexes telles que la détection de mouvement et la reconnaissance de formes dynamiques. Du point de vue informatique ces modèles offrent de nouveaux algorithmes, avec des propriétés intéressantes telles que l'utilisation de mémoire distribuée et la robustesse. La détection de mouvement et la discrimination de motifs visuels complexes à partir de ce signal (ou "vision cognitive") structurent les deux parties dans lesquelles le manuscrit se divise. La première partie porte sur la détection de mouvement en étudiant la façon dont l'extraction de caractéristiques visuelles est effectuée à partir du flux d'information visuel, et en particulier la façon dont les problèmes dus à la petite taille et la gamme de détection réduite des détecteurs de mouvement locaux peuvent être résolus. Dans la deuxième partie nous étudions la façon dont la classification des motifs visuels dynamiques complexes est réalisée à partir du traitement fourni par le système primaire de vision pour réaliser ce que nous appelons la vision cognitive, en évaluant au passage différentes techniques d'extraction de caractéristiques visuelles.
thesis.pdf (5.7 Mo) Télécharger le fichier
tel-00642818 , version 1 (18-11-2011)
  • HAL Id : tel-00642818 , version 1
Mauricio Cerda. Distributed neural computation for the visual perception of motion. Computer science. Université Nancy II, 2011. English. ⟨NNT : ⟩. ⟨tel-00642818⟩
304 Consultations
380 Téléchargements
