Architecture logicielle pour l'adaptation distribuée : Application à la réplication de données - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Theses Year : 2011
Software architecture for distributed adaptation : application for data replication
Dynamic adaptation allows the modification of an application during its execution, according to the fluctuations in its environment and changes in users' requirements. Several studies have proposed methods and mechanisms to adapt a centralized application. But the case of distributed applications has not been substantially addressed. In particular, the distribution of the adaptation system itself has been rarely considered. In this thesis, we propose an approach to define a component-based software architecture supporting the distributed and coordinated management of dynamic adaptation. We define a software architectural model of adaptation systems that allows the variability of the system configuration and includes coordination mechanisms that can be specialized. The chosen application domain to illustrate our adaptation approach was the replicated data management. In this domain, we have developed a prototype for the construction of distributed adaptation systems on one hand and replication systems on the other hand. The prototype, based on the Fractal component model, has enabled us to experiment on distributing adaptation of a data replication system in a medical environment, dedicated to remote monitoring of patients at home.
L'adaptation dynamique permet de modifier une application en cours d'exécution en fonction des fluctuations de son environnement et des changements des exigences des utilisateurs. De nombreux travaux ont proposé des méthodes et mécanismes pour adapter une application centralisée. Mais, le cas des applications distribuées a été beaucoup moins abordé. En particulier, la distribution du système d'adaptation lui-même est très peu envisagée. Nous proposons dans cette thèse une approche visant à définir une architecture logicielle à base de composants pour permettre la gestion distribuée et coordonnée de l'adaptation dynamique d'applications. Nous définissons un modèle d'architecture logicielle de systèmes d'adaptation qui permet la variabilité des configurations du système et qui inclut des mécanismes spécialisables pour assurer la coordination. Le domaine d'application choisi pour illustrer notre approche d'adaptation est la gestion de données répliquées. Dans ce domaine, nous avons développé un prototype pour la construction de systèmes d'adaptation distribués d'une part, et de systèmes de réplication d'autre part. Le prototype, qui se base sur le modèle de composants Fractal, nous a permis de mener des expérimentations d'adaptation distribuée sur un système de réplication de données en milieu médical pour le suivi d'un patient à domicile.
These.pdf (6.59 Mo) Télécharger le fichier
Dates and versions
tel-00652046 , version 1 (15-12-2011)
Identifiers
  • HAL Id : tel-00652046 , version 1
Cite
Mohamed Zouari. Architecture logicielle pour l'adaptation distribuée : Application à la réplication de données. Génie logiciel [cs.SE]. Université Rennes 1, 2011. Français. ⟨NNT : ⟩. ⟨tel-00652046⟩
732 View
1796 Download
Share
