An Algebraic Approach for Scientific Workflows with Large Scale Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2011
Une Approche Algébrique pour les Workflows Scientifiques Orientés-Données
Scientific workflows have emerged as a basic abstraction for structuring and executing scientific experiments in computational simulations. In many situations, these workflows are computationally and data intensive, thus requiring execution in large-scale parallel computers. However, the parallelization of scientific workflows is low-level, ad hoc and labor-intensive, which makes it hard to exploit optimization opportunities. To address the problem of optimizing the parallel execution of scientific workflows, we propose an algebraic approach to represent the workflow and a parallel execution model that together enable the automatic optimization of the parallel execution of scientific workflows. We conducted a thorough validation of our approach using both real applications and synthetic data scenarios. The experiments were run in Chiron, a data-centric scientific workflow engine implemented to parallelize scientific workflow execution. Our experiments demonstrated excellent parallel performance improvements obtained and evidenced through our algebraic approach several optimization opportunities when compared to ad hoc workflow implementation.
Os workflows científicos emergiram como uma abstração básica para estruturar experimentos científicos baseados em simulações computacionais. Em muitas situações, estes workflows são intensivos, seja computacionalmente seja quanto em relação à manipulação de dados, exigindo a execução em ambientes de processamento de alto desempenho. Entretanto, paralelizar a execução de workflows científicos requer programação trabalhosa, de modo ad hoc e em baixo nível de abstração, o que torna difícil a exploração das oportunidades de otimização. Visando a abordar o problema de otimizar a execução paralela de workflows científicos, esta tese propõe uma abordagem algébrica para especificar o workflow, bem como um modelo de execução que, juntos, possibilitam a otimização automática da execução paralela de workflows científicos. A tese apresenta uma avaliação ampla da abordagem usando tanto experimentos reais quanto dados sintéticos. Os experimentos foram avaliados no Chiron, um motor de execução de workflows desenvolvido para apoiar a execução paralela de workflows científicos. Os experimentos apresentaram resultados excelentes de paralelização na execução de workflows e evidenciaram, com a abordagem algébrica, diversas possibilidades de otimização de desempenho quando comparados a execuções paralelas de workflow de modo ad hoc.
TeseV23.pdf (3.19 Mo) Télécharger le fichier
tel-00653661 , version 1 (04-01-2012)
tel-00653661 , version 2 (19-04-2012)
  • HAL Id : tel-00653661 , version 1
Eduardo Ogasawara. An Algebraic Approach for Scientific Workflows with Large Scale Data. Databases [cs.DB]. Universidade Federal de Rio de Janeiro, 2011. Portuguese. ⟨NNT : ⟩. ⟨tel-00653661v1⟩
361 Consultations
775 Téléchargements
