Simulation d'images d'un futur imageur multispectral géostationaire dédié à la couleur de l'eau : étude de l'influence des angles d'observation et d'éclairement sur la luminance mesurée et sur l'erreur d'estimation en chlorophylle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2011
Image simulation of future geostationnary multispectral sensor dedicated to water color : Assessment of solar and sensor angles influence on measured radiance and chlorophyll estimation error
Improvements of optical sensors now make it possible to launch medium spatial and high spectral resolution sensors on the Geostationary Earth Orbit (GEO). The GEO allows sensors to observe the Earth with high temporal resolution, unlike Low Earth Orbit (LEO) satellites. The objective of this thesis is to simulate radiance images that would be provided by a theoretical ocean color sensor, on a geostationary orbit, in order to characterize the images to be acquired, to specify the future instruments and to validate the image processing algorithms. For this purpose, we have combined a radiative transfer model for ocean waters (Hydrolight) and a radiative transfer model for the atmosphere (MODTRAN) to obtain simulated radiance images at the sea surface level and at the Top-Of-Atmosphere (TOA) level. The inputs of Hydrolight have been deduced from GlobColour Project data (chlorophyll, mineral suspended matter and organic matter) to simulate the Global Area Coverage (GAC) images of a geostationary sensor with low spatial resolution, medium spectral resolution and high temporal resolution. The analysis of these images enables to determine the radiance dynamic range for each spectral band over the day. The results indicate the angular limits to avoid the sunglint phenomenon and to ensure a minimum proportion of water leaving radiance in the measured TOA radiance. The simulated radiance images allow to evaluate the performance of an ocean color algorithm for chlorophyll concentration estimation in open waters. The results show that the error of chlorophyll estimation is moderately sensitive to observation and lighting angles, which are so important in geostationary images.
Les progrès effectués dans le domaine des instruments optiques permettent d’envisager désormais de placer des capteurs à moyenne résolution spatiale et haute résolution spectrale sur des orbites géostationnaires ce qui permettrait d’observer la Terre à la fois avec une moyenne résolution spatiale, une bonne résolution spectrale et une haute résolution temporelle, ce que ne permettent pas les satellites héliosynchrones. L'objectif de cette thèse est donc de simuler les images en luminance qui seraient acquises par un capteur géostationnaire hypothétique dédié à l'observation de la couleur de l'océan, afin de caractériser les images qui seraient acquises, de spécifier les futurs instruments et de valider des algorithmes de traitement sur des images réalistes. Pour parvenir à simuler les luminances spectrales qui seraient mesurées par le capteur, nous avons combiné les modèles de transfert radiatif directs de l'eau (Hydrolight) et de l'atmosphère (MODTRAN). Les données d’entrée d’Hydrolight ont été déduites des données provenant des cartes climatologiques de GlobColour (chlorophylle, matières minérales et organiques en suspension) pour simuler des images de couverture globale (Global Area Coverage) d'un capteur géostationnaire à basse résolution spatiale, moyenne résolution spectrale et haute résolution temporelle. L'analyse de ces images permet de déterminer la gamme de luminances pour chaque bande spectrale et pour différentes acquisitions au cours de la journée. Les résultats indiquent aussi les limites angulaires pour éviter le phénomène du sunglint et pour assurer un niveau minimum de luminance provenant de l'eau, contenu dans le signal mesuré. Les images en luminance ainsi simulées ont permis d’évaluer aussi la performance d’un algorithme d'estimation de concentration en chlorophylle de rapport de bandes dans les eaux au large. Les résultats montrent que l'erreur d'estimation est moyennement sensible aux angles d'observation et d’éclairement, importants dans les images géostationnaires.
these_A_LEI_Manchun_2011.pdf (5.31 Mo) Télécharger le fichier
tel-00728820 , version 1 (06-09-2012)
  • HAL Id : tel-00728820 , version 1
Manchun Lei. Simulation d'images d'un futur imageur multispectral géostationaire dédié à la couleur de l'eau : étude de l'influence des angles d'observation et d'éclairement sur la luminance mesurée et sur l'erreur d'estimation en chlorophylle. Autre [cs.OH]. Université de Bourgogne, 2011. Français. ⟨NNT : 2011DIJOS084⟩. ⟨tel-00728820⟩
326 Consultations
730 Téléchargements
