Application de l'identification d'objets sur images à l'étude de canopées de peuplements forestiers tropicaux : cas des plantations d'Eucalyptus et des mangroves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2012
Object identification on remote sensing images of tropical forest canopies - applications to the study of Eucalyptus plantation and mangrove forest
This PhD work aims at providing information on the forest structure through the analysis of canopy properties as described by the spatial distribution and the crown size of dominant trees. Our approach is based on the Marked Point Processes (MPP) theory, which allows modeling tree crowns observed in remote sensing images by discs belonging a two dimensional space. The potential of MPP to detect the trees crowns automatically is evaluated by using very high spatial resolution optical satellite images of both Eucalyptus plantations and mangrove forest. Lidar and simulated reflectance images are also analyzed for the mangrove application. Different adaptations (parameter settings, energy models) of the MPP method are tested and compared through the development of quantitative indices that allow comparison between detection results and tree references derived from the field, photo-interpretation or the forest mockups. In the case of mangroves, the estimated crown sizes from detections are consistent with the outputs from the available allometric models. Other results indicate that tree detection by MPP allows mapping, the local density of trees of young Eucalyptus plantations even if crown size is close to the image spatial resolution (0.5m). However, the quality of detection by MPP decreases with canopy closeness. To improve the results, further work may involve MPP detection using objects with finer shapes and forest data measurements collected at the tree plant scale.
La thèse s'inscrit dans l'étude de la structuration des forêts à partir des propriétés de la canopée telles que décrites par la distribution spatiale ou la taille des houppiers des arbres dominants. L'approche suivie est fondée sur la théorie des Processus Ponctuels Marqués (PPM) qui permet de modéliser ces houppiers comme des disques sur images considérées comme un espace 2D. Le travail a consisté à évaluer le potentiel des PPM pour détecter automatiquement les houppiers d'arbres dans des images optiques de très résolution spatiale acquises sur des forêts de mangroves et des plantations d'Eucalyptus. Pour les mangroves, nous avons également travaillé sur des images simulées de réflectance et des données Lidar. Différentes adaptations (paramétrage, modèles d'énergie) de la méthode de PPM ont été testées et comparées grâce à des indices quantitatifs de comparaison entre résultats de la détection et références de positionnement issues du terrain, de photo-interprétation ou de maquettes forestières. Dans le cas des mangroves, les tailles de houppier estimées par détection restent cohérentes avec les sorties des modèles allométriques disponibles. Les résultats thématiques indiquent que la détection par PPM permet de cartographier dans une jeune plantation d'Eucalyptus la densité locale d'arbres dont la taille des houppiers est proche de la résolution spatiale de l'image (0.5m). Cependant, la qualité de la détection diminue quand le couvert se complexifie. Ce travail dresse plusieurs pistes de recherche tant mathématique, comme la prise en compte des objets de forme complexe, que thématiques, comme l'apport des informations forestières à des échelles pertinentes pour la mise au point de méthodes de télédétection.
memoire.pdf (21.67 Mo) Télécharger le fichier
tel-00763706 , version 1 (11-12-2012)
  • HAL Id : tel-00763706 , version 1
  • PRODINRA : 327021
Jia Zhou. Application de l'identification d'objets sur images à l'étude de canopées de peuplements forestiers tropicaux : cas des plantations d'Eucalyptus et des mangroves. Ecosystèmes. Université Montpellier II - Sciences et Techniques du Languedoc, 2012. Français. ⟨NNT : ⟩. ⟨tel-00763706⟩
605 Consultations
1286 Téléchargements
