Surrogate-Assisted Evolutionary Algorithms
Evolutionary Algorithms (EAs) have received a lot of attention regarding their potential to solve complex optimization problems using problem-specific variation operators. A search directed by a population of candidate solutions is quite robust with respect to a moderate noise and multi-modality of the optimized function, in contrast to some classical optimization methods such as quasi-Newton methods. The main limitation of EAs, the large number of function evaluations required, prevents from using EAs on computationally expensive problems, where one evaluation takes much longer than 1 second. The present thesis focuses on an evolutionary algorithm, Covariance Matrix Adaptation Evolution Strategy (CMA-ES), which has become a standard powerful tool for \textit{continuous black-box optimization}. We present several state-of-the-art algorithms, derived from CMA-ES, for solving single- and multi-objective black-box optimization problems. First, in order to deal with expensive optimization, we propose to use comparison-based surrogate (approximation) models of the optimized function, which do not exploit function values of candidate solutions, but only their quality-based ranking. The resulting self-adaptive surrogate-assisted CMA-ES represents a tight coupling of statistical machine learning and CMA-ES, where a surrogate model is build, taking advantage of the function topology given by the covariance matrix adapted by CMA-ES. This allows to preserve two key invariance properties of CMA-ES: invariance with respect to i). monotonous transformation of the function, and ii). orthogonal transformation of the search space. For multi-objective optimization we propose two mono-surrogate approaches: i). a mixed variant of One Class Support Vector Machine (SVM) for dominated points and Regression SVM for non-dominated points; ii). Ranking SVM for preference learning of candidate solutions in the multi-objective space. We further integrate these two approaches into multi-objective CMA-ES (MO-CMA-ES) and discuss aspects of surrogate-model exploitation. Second, we introduce and discuss various algorithms, developed to understand, explore and expand frontiers of the Evolutionary Computation domain, and CMA-ES in particular. We introduce linear time Adaptive Coordinate Descent method for non-linear optimization, which inherits a CMA-like procedure of adaptation of an appropriate coordinate system without losing the initial simplicity of Coordinate Descent. For multi-modal optimization we propose to adaptively select the most suitable regime of restarts of CMA-ES and introduce corresponding alternative restart strategies. For multi-objective optimization we analyze case studies, where original parent selection procedures of MO-CMA-ES are inefficient, and introduce reward-based parent selection strategies, focused on a comparative success of generated solutions.
Les Algorithmes Évolutionnaires (AEs) ont été très étudiés en raison de leur capacité à résoudre des problèmes d'optimisation complexes en utilisant des opérateurs de variation adaptés à des problèmes spécifiques. Une recherche dirigée par une population de solutions offre une bonne robustesse par rapport à un bruit modéré et la multi-modalité de la fonction optimisée, contrairement à d'autres méthodes d'optimisation classiques telles que les méthodes de quasi-Newton. La principale limitation de AEs, le grand nombre d'évaluations de la fonction objectif, pénalise toutefois l'usage des AEs pour l'optimisation de fonctions chères en temps calcul. La présente thèse se concentre sur un algorithme évolutionnaire, Covariance Matrix Adaptation Evolution Strategy (CMA-ES), connu comme un algorithme puissant pour l'optimisation continue boîte noire. Nous présentons l'état de l'art des algorithmes, dérivés de CMA-ES, pour résoudre les problèmes d'optimisation mono- et multi-objectifs dans le scénario boîte noire. Une première contribution, visant l'optimisation de fonctions coûteuses, concerne l'approximation scalaire de la fonction objectif. Le meta-modèle appris respecte l'ordre des solutions (induit par la valeur de la fonction objectif pour ces solutions) ; il est ainsi invariant par transformation monotone de la fonction objectif. L'algorithme ainsi défini, saACM-ES, intègre étroitement l'optimisation réalisée par CMA-ES et l'apprentissage statistique de meta-modèles adaptatifs ; en particulier les meta-modèles reposent sur la matrice de covariance adaptée par CMA-ES. saACM-ES préserve ainsi les deux propriété clé d'invariance de CMA-ES~: invariance i) par rapport aux transformations monotones de la fonction objectif; et ii) par rapport aux transformations orthogonales de l'espace de recherche. L'approche est étendue au cadre de l'optimisation multi-objectifs, en proposant deux types de meta-modèles (scalaires). La première repose sur la caractérisation du front de Pareto courant (utilisant une variante mixte de One Class Support Vector Machone (SVM) pour les points dominés et de Regression SVM pour les points non-dominés). La seconde repose sur l'apprentissage d'ordre des solutions (rang de Pareto) des solutions. Ces deux approches sont intégrées à CMA-ES pour l'optimisation multi-objectif (MO-CMA-ES) et nous discutons quelques aspects de l'exploitation de meta-modèles dans le contexte de l'optimisation multi-objectif. Une seconde contribution concerne la conception d'algorithmes nouveaux pour l'optimi\-sation mono-objectif, multi-objectifs et multi-modale, développés pour comprendre, explorer et élargir les frontières du domaine des algorithmes évolutionnaires et CMA-ES en particulier. Spécifiquement, l'adaptation du système de coordonnées proposée par CMA-ES est couplée à une méthode adaptative de descente coordonnée par coordonnée. Une stratégie adaptative de redémarrage de CMA-ES est proposée pour l'optimisation multi-modale. Enfin, des stratégies de sélection adaptées aux cas de l'optimisation multi-objectifs et remédiant aux difficultés rencontrées par MO-CMA-ES sont proposées.
