Modélisation probabiliste et inférence par l'algorithme Belief Propagation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Probabilistic Modelling and Inference using the Belief Propagation Algorithm
In this work, we focus on the design and estimation - from partial observations - of graphical models of real-valued random variables. These models should be suited for a non-standard regression problem where the identity of the observed variables (and therefore of the variables to predict) changes from an instance to the other. The nature of the problem and of the available data lead us to model the network as a Markov random field, a choice consistent with Jaynes' maximum entropy principle. For the prediction task, we turn to the Belief Propagation algorithm - in its classical or Gaussian flavor - which simplicity and efficiency make it usable on large scale networks. After providing a new result on the local stability of the algorithm's fixed points, we propose an approach based on a latent Ising model, where dependencies between real-valued variables are encoded through a network of binary variables. To this end, we propose a definition of these variables using the cumulative distribution functions of the real-valued variables. For the prediction task, it is necessary to modify the Belief Propagation algorithm in order to impose Bayesian-like constraints on marginal distributions of the binary variables. Estimation of the model parameters can easily be performed using only pairwise observations. In fact, this approach is a way to solve the regression problem by working on quantiles. Furthermore, we propose a greedy algorithm for estimating both the structure and the parameters of a Gauss-Markov random field based on the Iterative Proportional Scaling procedure. At each iteration, the algorithm yields a new model which likelihood, or an approximation of it in the case of partial observations, is higher than the one of the previous model. Because of its local perturbation principle, this algorithm allows us to impose spectral constraints, increasing the compatibility with the Gaussian Belief Propagation algorithm. The performances of all approaches are empirically illustrated on synthetic data.
On s'intéresse à la construction et l'estimation - à partir d'observations incomplètes - de modèles de variables aléatoires à valeurs réelles sur un graphe. Ces modèles doivent être adaptés à un problème de régression non standard où l'identité des variables observées (et donc celle des variables à prédire) varie d'une instance à l'autre. La nature du problème et des données disponibles nous conduit à modéliser le réseau sous la forme d'un champ markovien aléatoire, choix justifié par le principe de maximisation d'entropie de Jaynes. L'outil de prédiction choisi dans ces travaux est l'algorithme Belief Propagation - dans sa version classique ou gaussienne - dont la simplicité et l'efficacité permettent son utilisation sur des réseaux de grande taille. Après avoir fourni un nouveau résultat sur la stabilité locale des points fixes de l'algorithme, on étudie une approche fondée sur un modèle d'Ising latent où les dépendances entre variables réelles sont encodées à travers un réseau de variables binaires. Pour cela, on propose une définition de ces variables basée sur les fonctions de répartition des variables réelles associées. Pour l'étape de prédiction, il est nécessaire de modifier l'algorithme Belief Propagation pour imposer des contraintes de type bayésiennes sur les distributions marginales des variables binaires. L'estimation des paramètres du modèle peut aisément se faire à partir d'observations de paires. Cette approche est en fait une manière de résoudre le problème de régression en travaillant sur les quantiles. D'autre part, on propose un algorithme glouton d'estimation de la structure et des paramètres d'un champ markovien gaussien, basé sur l'algorithme Iterative Proportional Scaling. Cet algorithme produit à chaque itération un nouveau modèle dont la vraisemblance, ou une approximation de celle-ci dans le cas d'observations incomplètes, est supérieure à celle du modèle précédent. Cet algorithme fonctionnant par perturbation locale, il est possible d'imposer des contraintes spectrales assurant une meilleure compatibilité des modèles obtenus avec la version gaussienne de Belief Propagation. Les performances des différentes approches sont illustrées par des expérimentations numériques sur des données synthétiques.
these.pdf (1.52 Mo) Télécharger le fichier
Slides.pdf (1.23 Mo) Télécharger le fichier
Format : Autre
tel-00867693 , version 1 (30-09-2013)
tel-00867693 , version 2 (18-10-2013)
  • HAL Id : tel-00867693 , version 1
Victorin Martin. Modélisation probabiliste et inférence par l'algorithme Belief Propagation. Modélisation et simulation. Ecole Nationale Supérieure des Mines de Paris, 2013. Français. ⟨NNT : ⟩. ⟨tel-00867693v1⟩
1005 Consultations
958 Téléchargements
