Pursuit-Evasion, Decompositions and Convexity on Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Jeux de Poursuite-Evasion, Décompositions et Convexité dans les Graphes
This thesis focuses on the study of structural properties of graphs whose understanding enables the design of efficient algorithms for solving optimization problems. We are particularly interested in methods of decomposition, pursuit-evasion games and the notion of convexity. The Process game has been defined as a model for the routing reconfiguration problem in WDM networks. Often, such games where a team of searchers have to clear an undirected graph are closely related to graph decompositions. In digraphs, we show that the Process game is monotone and we define a new equivalent digraph decomposition. Then, we further investigate graph decompositions. We propose a unified FPT-algorithm to compute several graph width parameters. This algorithm turns to be the first FPT-algorithm for the special and the q-branched tree-width of a graph. We then study another pursuit-evasion game which models prefetching problems. We introduce the more realistic online variant of the Surveillance game. We investigate the gap between the classical Surveillance Game and its connected and online versions by providing new bounds. We then define a general framework for studying pursuit-evasion games, based on linear programming techniques. This method allows us to give first approximation results for some of these games. Finally, we study another parameter related to graph convexity and to the spreading of infection in networks, namely the hull number. We provide several complexity results depending on the graph structures making use of graph decompositions. Some of these results answer open questions of the literature.
Cette thèse porte sur l'étude des propriétés structurelles de graphes dont la compréhension permet de concevoir des algorithmes efficaces pour résoudre des problèmes d'optimisation. Nous nous intéressons plus particulièrement aux méthodes de décomposition des graphes, aux jeux de poursuites et à la notion de convexité. Le jeu de Processus a été défini comme un modèle de la reconfiguration de routage. Souvent, ces jeux où une équipe de chercheurs doit traiter les sommets d'un graphe non orienté sont reliés aux décompositions de graphes. Dans les graphes dirigés, nous montrons que le jeu de Processus est monotone et nous définissons une nouvelle décomposition de graphes que lui est équivalente. Ensuite, nous étudions d'autres décompositions de graphes. Nous proposons un algorithme FPT unifié pour calculer plusieurs paramètres de largeur de graphes. En particulier, ceci est le premier FPT-algorithme pour la largeur arborescente q-branchée et pour la largeur arborescente spéciale d'un graphe. Nous étudions ensuite un autre jeu qui modélise les problèmes de pré-chargement. Nous introduisons la variante en ligne du jeu de surveillance. Nous étudions l'écart entre le jeu de surveillance classique et ses versions connectée et en ligne, en fournissant de nouvelles bornes. Nous définissons ensuite un cadre général pour l'étude des jeux poursuite-évasion. Cette méthode nous permet de donner les premiers résultats d'approximation pour certains de ces jeux. Finalement, nous étudions un autre paramètre lié à la convexité des graphes et à la propagation d'infection dans les réseaux, le enveloppe convexe. Nous fournissons plusieurs résultats de complexité en fonction des structures des graphes et en utilisant des décompositions de graphes.
Thesis-Ronan-22112013.pdf (1.6 Mo) Télécharger le fichier
tel-00908227 , version 1 (22-11-2013)
tel-00908227 , version 2 (06-02-2014)
  • HAL Id : tel-00908227 , version 1
Ronan Pardo Soares. Pursuit-Evasion, Decompositions and Convexity on Graphs. Computational Complexity [cs.CC]. Université Nice Sophia Antipolis, 2013. English. ⟨NNT : ⟩. ⟨tel-00908227v1⟩
485 Consultations
1035 Téléchargements
