On Some Unsupervised Learning Problems for Highly Dependent Time Series - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Sur quelques problèmes non-supervisés impliquant des séries temporelles hautement dèpendantes
This thesis is devoted to the theoretical analysis of unsupervised learning problems involving highly dependent time-series. Two fundamental problems are considered, namely, the problem of change point estimation as well as that of time-series clustering. The problems are considered in an extremely general framework, where the data are assumed to be generated by arbitrary, unknown stationary ergodic process distributions. This is one of the weakest assumptions in statistics, because it is more general than the parametric and model-based settings, and it subsumes most of the non-parametric frameworks considered for this class of problems. These assumptions typically have the premise that each time-series consists of independent and identically distributed observations or that it satisfies certain mixing conditions. For each of the considered problems, novel nonparametric methods are proposed, and are further shown to be asymptotically consistent in this general framework. For change point estimation, asymptotic consistency refers to the algorithm's ability to produce change point estimates that are asymptotically arbitrarily close to the true change points. On the other hand, a clustering algorithm is asymptotically consistent, if the output clustering, restricted to each fixed batch of sequences, consistently coincides with the target clustering from some time on. The proposed algorithms are shown to be efficiently implementable, and the theoretical results are complemented with experimental evaluations. Statistical analysis in the stationary ergodic framework is extremely challenging. In general, rates of convergence (even of frequencies to respective probabilities) are provably impossible to obtain for this class of processes. As a result, given a pair of samples generated independently by stationary ergodic process distributions, it is provably impossible to distinguish between the case where they are generated by the same process or by two different ones. This in turn, implies that such problems as time-series clustering with unknown number of clusters, or change point detection, cannot possibly admit consistent solutions. Thus, a challenging task is to discover the problem formulations which admit consistent solutions in this general framework. The main contribution of this thesis is to constructively demonstrate that despite these theoretical impossibility results, natural formulations of the considered problems exist which admit consistent solutions in this general framework. Specifically, natural formulations of change-point estimation and time-series clustering are proposed, and efficient algorithms are provided, which are shown to be asymptotically consistent under the assumption that the process distributions are stationary ergodic. This includes the demonstration of the fact that the correct number of change points can be found, without the need to impose stronger assumptions on the process distributions. It turns out that in this formulation the change point estimation problem can be reduced to time-series clustering. The results presented in this work lay down the theoretical foundations for the analysis of sequential data in a broad range of real-world applications.
Cette thèse est consacrée à l'analyse théorique de problèmes non supervisés impliquant des séries temporelles hautement dépendantes. Plus particulièrement, nous abordons les deux problèmes fondamentaux que sont le problème d'estimation des points de rupture et le partitionnement de séries temporelles. Ces problèmes sont abordés dans un cadre extrêmement général oùles données sont générées par des processus stochastiques ergodiques stationnaires. Il s'agit de l'une des hypothèses les plus faibles en statistiques, comprenant non seulement, les hypothèses de modèles et les hypothèses paramétriques habituelles dans la littérature scientifique, mais aussi des hypothèses classiques d'indépendance, de contraintes sur l'espace mémoire ou encore des hypothèses de mélange. En particulier, aucune restriction n'est faite sur la forme ou la nature des dépendances, de telles sortes que les échantillons peuvent être arbitrairement dépendants. Pour chaque problème abordé, nous proposons de nouvelles méthodes non paramétriques et nous prouvons de plus qu'elles sont, dans ce cadre, asymptotiquement consistantes. Pour l'estimation de points de rupture, la consistance asymptotique se rapporte à la capacité de l'algorithme à produire des estimations des points de rupture qui sont asymptotiquement arbitrairement proches des vrais points de rupture. D'autre part, un algorithme de partitionnement est asymptotiquement consistant si le partitionnement qu'il produit, restreint à chaque lot de séquences, coïncides, à partir d'un certain temps et de manière consistante, avec le partitionnement cible. Nous montrons que les algorithmes proposés sont implémentables efficacement, et nous accompagnons nos résultats théoriques par des évaluations expérimentales. L'analyse statistique dans le cadre stationnaire ergodique est extrêmement difficile. De manière générale, il est prouvé que les vitesses de convergence sont impossibles à obtenir. Dès lors, pour deux échantillons générés indépendamment par des processus ergodiques stationnaires, il est prouvé qu'il est impossible de distinguer le cas où les échantillons sont générés par le même processus de celui où ils sont générés par des processus différents. Ceci implique que des problèmes tels le partitionnement de séries temporelles sans la connaissance du nombre de partitions ou du nombre de points de rupture ne peut admettre de solutions consistantes. En conséquence, une tâche difficile est de découvrir les formulations du problème qui en permettent une résolution dans ce cadre général. La principale contribution de cette thèse est de démontrer (par construction) que malgré ces résultats d'impossibilités théoriques, des formulations naturelles des problèmes considérés existent et admettent des solutions consistantes dans ce cadre général. Ceci inclut la démonstration du fait que le nombre de points de rupture corrects peut être trouvé, sans recourir à des hypothèses plus fortes sur les processus stochastiques. Il en résulte que, dans cette formulation, le problème des points de rupture peut être réduit à du partitionnement de séries temporelles. Les résultats présentés dans ce travail formulent les fondations théoriques pour l'analyse des données séquentielles dans un espace d'applications bien plus large.
Thesis.pdf (1.13 Mo) Télécharger le fichier
tel-00920184 , version 1 (17-12-2013)
  • HAL Id : tel-00920184 , version 1
Azadeh Khaleghi. On Some Unsupervised Learning Problems for Highly Dependent Time Series. Statistics [math.ST]. Institut national de recherche en informatique et en automatique (INRIA), 2013. English. ⟨NNT : ⟩. ⟨tel-00920184⟩
396 Consultations
1269 Téléchargements
