Codes AL-FEC et protocoles de diffusion robuste de contenus : composants pour des services performants et passant à l'échelle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hdr Année : 2014
AL-FEC codes and robust content distribution protocols: components for high performance and scalable services
This work focuses on the provision of broadcast services where contents of any kinds must be transmitted in an efficient manner to a set of receivers. Several problems arise: - the robustness in front of transmission issues, no matter whether it consists of errors (bit inversion) or erasures (of packets); - the efficiency of the provided service, in terms of error and/or erasure recovery performance and low algorithmic complexity; - the fulfilment of the potential real-time constraints of some contents; - and finally the scalability of the service when the number of receivers significantly increases. The problem space is rather large and we "limit ourself" to two essential components, namely: - the application-level correction codes, or AL-FEC,for the erasure channel and without which the efficiency of the service would be largely compromised, and - the transport protocols that define the rules for the exchange of information between the source(s) and the destination(s), and provide the required reliability. Throughout this document, we detail these two axes and position our contributions and their actual usage in the current situation.
Ce document discute de la fourniture de services de diffusion où des contenus de toute nature doivent être transmis efficacement à un ensemble de récepteurs. Plusieurs problèmes se posent : - la robustesse face aux problèmes de transmission, qu'il s'agisse d'erreurs (inversion de bits) ou de pertes (de paquets); - l'efficacité du service fourni, en termes de performances de correction d'erreurs et/ou effacements, et de faible complexité algorithmique; - le respect d'éventuelles contraintes temps réelles de certains contenus; - et enfin le passage à l'échelle lorsque le nombre de récepteur augmente significativement. La problématique est assez large et nous nous "limitons" à deux aspects et composants essentiels que sont : - les codes correcteurs de niveau applicatif, ou AL-FEC, pour le canal à effacements, sans lesquels l'efficacité du service serait fortement compromise, et - les protocoles de transport qui définissent les règles d'échanges d'informations entre soure(s) et récep- teur(s) et garantissent le niveau de fiabilité nécessaire. Tout au long de ce document, nous détaillons ces deux axes et positionnons nos contributions et leur usage effectif dans le panorama actuel.
hdr_v_roca_2014-02-20.pdf (11.09 Mo) Télécharger le fichier
tel-00925955 , version 1 (08-01-2014)
tel-00925955 , version 2 (20-02-2014)
  • HAL Id : tel-00925955 , version 2
Vincent Roca. Codes AL-FEC et protocoles de diffusion robuste de contenus : composants pour des services performants et passant à l'échelle. Réseaux et télécommunications [cs.NI]. Université de Grenoble, 2014. ⟨tel-00925955v2⟩
793 Consultations
858 Téléchargements
