Communication coopératives dans les réseaux autour du corps humain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Cooperative communications in Body Area Networks
This thesis aimed at studying the theoretical performance bounds of cooperative techniques in Body Area Networks (BAN). These networks are sensor networks, with a small number of nodes located on and inside the human body. Cooperative techniques are extremely dependent on the channel side information available at the time of transmission. Considering statistical information about the channel fading and the short-term mean of the signal, we derive an asymptotic approximation of the packet error rate under the so-called block fading channel model. Using this approximation, we can express in closed-form asymptotically optimal power allocation among transmitting nodesfor various models of relay channels. Under a complete channel knowledge hypothesis, we then study the Shannon capacity of small-scale cooperative networks, namely relay channels and cooperative multiple access channels. We show that for these networks, when you aim at optimizing the global power allocation of the whole network, the problem is equivalent to a simpler problem on an equivalent channel model. Using this equivalence, we are able to derive a number of closed-form resource allocation for relay channels and cooperative multiple access channels. In the last part of the manuscript, we present a measurement platform for BAN where the quality of every link in the network is gathered in a quasi-simultaneous manner. This platform allows us to discuss results and assess hypotheses on the stability and reciprocity of BAN links. We also evaluate the variation of the spatial correlation of the links during a walking scenario, and show that although the correlation matrix may vary a lot during the movement, it does so sufficiently slowly to be estimated on-line by an adequate protocole, paving the way to more precise resource allocation techniques and relay selection protocols.
Cette thèse a pour but d'évaluer la performance théorique des approches coopératives pour la fiabilisation des transmissions dans les réseaux autour du corps humain. Ces réseaux sont formés d'un nombre limité de capteurs communiquants disposés sur et dans le corps. Les techniques de coopération dans les réseaux de cette taille sont extrêmement dépendantes de l'information disponible quant à la qualité des canaux de communication au moment de la transmission. Sous une hypothèse de connaissance de la valeur moyenne à moyen et long terme de l'affaiblissement de ces canaux, nous dérivons une approximation du taux d'erreur paquet de bout en bout pour des techniques de relayage. Nous présentons également, pour certains de ces modèles, une allocation de puissance asymptotiquement optimale, fournissant néanmoins un gain en performance sur une large plage de puissances d'émission. En supposant ensuite que les noeuds ont une connaissance parfaite de l'état du réseau, nous étudions la capacité de Shannon sur des canaux à relais et des canaux comprenant deux émetteurs coopérant entre eux. Pour ces deux modèles, nous montrons que lorsque l'on cherche à optimiser la répartition de la puissance totale disponible à l'émission, l'étude se réduit à celle d'un modèle de canal équivalent, simplifiant grandement l'analyse de la région de capacité. Nous dérivons ensuite l'allocation de ressources optimale ou de bonnes approximations pour des protocoles de coopération adaptés à ces deux modèles. Nous présentons enfin une plate-forme de mesures pour les réseaux autour du corps humain nous permettant de relever de manière quasi-simultanée l'intégralité des affaiblissements des liens entre les noeuds du réseau. Cette plate-forme nous permet de traiter de la stabilité de la qualité des liens et de la validité de l'hypothèse de réciprocité de chaque lien. De plus, nous évaluons aussi la corrélation spatiale de l'affaiblissement des liens, et nous montrons en particulier que celle-ci varie fortement au cours du mouvement, mais de manière suffisament lente pour être estimée au fil de l'eau.
These.pdf (3.3 Mo) Télécharger le fichier
tel-00931788 , version 1 (15-01-2014)
tel-00931788 , version 2 (03-02-2014)
tel-00931788 , version 3 (28-06-2017)
  • HAL Id : tel-00931788 , version 1
Paul Ferrand. Communication coopératives dans les réseaux autour du corps humain. Traitement du signal et de l'image [eess.SP]. INSA de Lyon, 2013. Français. ⟨NNT : ⟩. ⟨tel-00931788v1⟩
579 Consultations
590 Téléchargements
