Sparse and scale invariant methods in image processing
Méthodes parcimonieuses et invariantes d’échelle en traitement d’images
In this thesis, we present new techniques based on the notions of sparsity and scale
invariance to design fast and efficient image processing applications. Instead of using
the popular l1-norm to model sparsity, we focus on the use of non-convex penalties
that promote more sparsity. We propose to use a first-order approximation to estimate
a solution of non-convex proximal operators, which permits to easily use a wide range
of penalties. We address also the problem of multi-sparsity, when the minimization
problem is composed of various sparse terms, which typically arises in problems that
require both a robust estimation to reject outliers and a sparse prior. These techniques
are applied to various important problems in low-level computer vision such as edgeaware
smoothing, image separation, robust integration and image deconvolution. We
propose also to go beyond sparsity models and learn non-local spectral mapping
with application to image denoising. Scale-invariance is another notion that plays
an important role in our work. Using this principle, a precise definition of edges can
be derived which can be complementary to sparsity. More precisely, we can extract
invariant features for classification from sparse representations in a deep convolutional
framework. Scale-invariance permits also to extract relevant pixels for sparsifying
images. We use this principle as well to improve optical flow estimation on turbulent
images by imposing a sparse regularization on the local singular exponents instead of
regular gradients.
Dans cette thèse, on présente de nouvelles approches à base de parcimonie et
d'invariance d'échelle pour le développement de techniques rapides et efficaces en
traitement d'images. Au lieu d'utiliser la norme l1 pour imposer la parcimonie, on
exploite plutôt des pénalités non-convexes qui encouragent plus la parcimonie. On
propose une approche de premier ordre pour estimer une solution d'un opérateur
proximal non-convexe, ce qui permet d'exploiter facilement la non-convexité. On
étudie aussi le problème de pluri-parcimonie quand le problème d'optimisation est
composé de plusieurs termes parcimonieux. Ce cas survient généralement dans les
problèmes qui nécessitent à la fois une estimation robuste pour rejeter les valeurs
aberrantes et exploiter une information de parcimonie connue a priori. Ces techniques
sont appliquées à plusieurs problèmes importants en vision par ordinateur
bas niveau telles que le lissage sélectif, la séparation d'images, l'intégration robuste
et la déconvolution. On propose aussi d'aller au-delà de la parcimonie et apprendre
un modèle de mapping spectral non-local pour le débruitage d'images. La
notion d'invariance d'échelle joue aussi un rôle important dans nos travaux. En
exploitant ce principe, une définition précise des contours est introduite, ce qui peut être
complémentaire de la notion de parcimonie. Plus précisément, on peut construire des
représentations invariantes pour la classification en se basant sur une architecture
de réseaux convolutionnels profonds. L'invariance d'échelle permet aussi d'extraire
les pixels qui portent les informations nécessaires pour la reconstruction ou aussi
améliorer l'estimation du flot optique sur les images turbulentes en imposant la
parcimonie comme régularisation sur les exposants de singularité locaux.
