Modèles de mémoires pour la navigation autonome - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2000
We propose a method for autonomous agent navigation problem grounded on a connectionist architecture inspired by neurobiological data concerning cortex and hippocampus. Our approach is grounded on distinction between memories : cerebral cortex is believed to be implied within declarative memory, allowing explicit memorization of facts and events. Our works concerns modeling of these memories in the framework of autonomous behavior. The study of these different memories underlines the importance of this procedural/declarative dichotomy in cognitive tasks while autonomous navigation study underlines the topological cognitive map notion as well as the necessity of having at disposal ad hoc memory systems. Our modeling work is separated in two parts.Available data concerning human cortex allow us to model a procedural memory for the construction of links between places of a simulated environment allowing a goal-guided search as well as the possibility of reaching anytime any known place in the environment. Furthermore, available data concerning hippocampus allow us to model a declarative memory system. The architecture of the model as well as the original mechanisms implied make this system able to handle both simulated and real-world data. THis model finally allows to characterize and memorize the different places of a given environment.
Nous proposons une approche du problème de la navigation d'un agent autonome fondée sur une architecture connexionniste inspirée de données biologiques concernant le cortex cérébral et l'hippocampe. Notre approche se fonde sur la distinction des mémoires, le cortex cérébral étant fortement impliqué dans la mémoire procédurale, permettant l'apprentissage de procédures, alors que l'hippocampe est impliqué dans la mémoire déclarative, permettant la mémorisation explicite de faits et d'événements.Notre travail concerne la modélisation de ces mémoires dans le contexte du comportement autonome. L'étude des différentes mémoires met en évidence l'importance de cette dichotomie procédurale/déclarative dans les tâches cognitives et l'étude de la navigation autonome met en exergue la notion de carte cognitive topologique ainsi que la nécessité de disposer de systèmes de mémoires adéquats. Notre travail de modélisation s'articule alors en deux temps. Les données concernant le cortex humain ont permis de modéliser une mémoire procédurale pour la construction des liens reliant les différents lieux d'un environnement simulé permettant une recherche guidée par le but ainsi que le ralliement à tout instant d'un lieu visité auparavant. Par ailleurs, les différentes données concernant la structure de l'hippocampe ont permis de proposer un modèle de mémoire de type déclaratif. L'architecture de ce modèle ainsi que les mécanismes originaux participant à son fonctionnement lui assurent une efficacité et une robustesse aussi bien sur des données simulées que sur des données réelles.Ce modèle permet alors de caractériser de façon adéquate les différents lieux d'un environnement donné.
Autre [cs.OH]
Fichier non déposé
tel-01746477 , version 2 (24-06-2011)
tel-01746477 , version 1 (29-03-2018)
  • HAL Id : tel-01746477 , version 1
Lien texte intégral
Nicolas Rougier. Modèles de mémoires pour la navigation autonome. Autre [cs.OH]. Université Henri Poincaré - Nancy 1, 2000. Français. ⟨NNT : 2000NAN10122⟩. ⟨tel-01746477v1⟩
544 Consultations
980 Téléchargements
