Gestion du temps par le raffinement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2009
Refinement Patterns for Real-Time Systems
Critical application domains of computer science require the use of software engineering methods that ensure that the resulting systems behave according to their intended functionality. In this context, the Event-B method uses an approach based on stepwise refinement, starting with abstract, high-level models of the system under development. The system models corresponding to different levels of abstraction are related by precise and formally proved refinement relations. Our goal is to extend this approach to systems whose requirements include quantitative real-time aspects (properties and temporal constraints). In this way, we benefit from the established qualities of the B method, while extending its scope to real-time aspects that it does not yet cover. More specifically, we propose to introduce time constraints by refinement, respecting the overall approach of the B method, and to systematize our approach by the use of refinement patterns. Different time models are represented by generic patterns that can be reused for the development of concrete systems. In this way we can gradually develop the system from a non-temporal abstraction and progressively validate its correctness, distributing the burden of proof is over several refinement steps. Temporal aspects are introduced step by step and only when necessary. We validated this approach using several real-world case studies, using the software tools for formal proof developed for the Event-B method.
Dans les domaines critiques d'application de l'informatique, il peut être vital de disposer d'un génie logiciel qui soit capable de garantir le bon fonctionnement des systèmes produits. Dans ce contexte, la méthode B évènementielle promeut le développement de modèles abstraits du système à concevoir et l'utilisation de démonstrations formelles ainsi que de la relation de raffinement entre les modèles. Notre but est de pouvoir travailler sur des systèmes ayant des aspects temporels quantitatifs (propriétés et contraintes de temps) en restant au sein du cadre défini par la méthode B qui a déjà montré son efficacité par ailleurs, mais qui ne dispose pas de concepts spécifiques pour le temps. C'est ainsi que nous proposons l'introduction des contraintes de temps par le raffinement, ceci permet de respecter la philosophie de la méthode B et de systématiser cette approche par la formalisation de patrons de raffinement. Nos différentes modélisations du temps sont proposées sous la forme de patron à réappliquer sur le système à étudier. Nous pouvons donc étudier progressivement le système à partir d'une abstraction non-temporelle afin de le valider progressivement et de distribuer la difficulté de la preuve en plusieurs étapes. L'introduction des aspects temporels ne se fait que lorsque cela est nécessaire lors du processus de développement prouvé. Nous avons validé cette approche sur des études de cas réalistes en utilisant les outils logiciels de démonstration formelle de la méthode B.
SCD_T_2009_0101_REHM.pdf (1.06 Mo) Télécharger le fichier
tel-01748288 , version 2 (15-12-2009)
tel-01748288 , version 1 (29-03-2018)
  • HAL Id : tel-01748288 , version 1
Joris Rehm. Gestion du temps par le raffinement. Autre [cs.OH]. Université Henri Poincaré - Nancy 1, 2009. Français. ⟨NNT : 2009NAN10101⟩. ⟨tel-01748288v1⟩
452 Consultations
813 Téléchargements
