Visual words for pose computation
Mots visuels pour le calcul de pose
We address the problem of establishing point correspondences in images for computing camera pose through Perspective-n-Point (PnP) algorithm. We compute the 3D map i.e. 3D coordinates and visual characteristics of some of the points in the environment through an offline training stage using a set of training images. Given a new test image we apply PnP using the 2D coordinates of 3D points in the image detected by using the 3D map. During the training stage we cluster the SIFT descriptors extracted from training images to obtain 2D-tracks of some of the 3D points in the environment. Each 2D-track consists of a set of 2D image coordinates of a single 3D point in different training images. SfM (Structure from Motion) is performed on these 2D-tracks to obtain the coordinates of the corresponding 3D points. During the test stage, the SIFT descriptors associated the 2D-track of a 3D point is used to recognize the 3D point in a given image. The overall process is similar to visual word framework used in different fields of computer vision. During training, visual word formation is performed through clustering and during testing 3D points are identified through visual word recognition. We experiment with different clustering schemes (k-means and mean-shift) and propose a novel scheme for visual word formation for training stage. We use different matching rules including some of the popular supervised pattern classification methods to perform visual word recognition during test stage. We evaluate these various matching strategies in both stages. In order to achieve robustness against pose variation between train and test images, we explore different ways of incorporating SIFT descriptors extracted from synthetic views generated from the training images. We also propose an exact acceleration strategy for mean-shift computation
Nous abordons le problème de la mise en correspondance de points dans des images pour calculer la pose d'une caméra par l'algorithme Perspective-n-Point (PnP). Nous calculons la carte 3D, c'est-à-dire les coordonnées 3D et les caractéristiques visuelles de quelques points dans l'environnement grâce à une procédure d'apprentissage hors ligne utilisant un ensemble d'images d'apprentissage. Étant donné une nouvelle image nous utilisons PnP à partir des coordonnées 2D dans l'image de points 3D détectés à l'aide de la carte 3D. Pendant la phase d'apprentissage nous groupons les descripteurs SIFT extraits des images d'apprentissage pour obtenir des collections de positions 2D dans ces images de quelques-uns des points 3D dans l'environnement. Le calcul de SFM (Structure From Motion) est effectué pour obtenir les coordonnées des points correspondants 3D. Pendant la phase de test, les descripteurs SIFT associés aux points 2D projection d'un point 3D de la carte sont utilisés pour reconnaître le point 3D dans une image donnée. Le cadre de travail est semblable à celui des mots visuels utilisés dans différents domaines de la vision par ordinateur. Pendant l'apprentissage, la formation des mots visuelle est effectuée via l'identification de groupes et pendant les tests des points 3D sont identifiés grâce à la reconnaissance des mots visuels. Nous menons des expériences avec des méthodes de formation différentes (k-means et mean-shift) et proposons un nouveau schéma pour la formation des mots visuels pour la phase d'apprentissage. Nous utilisons différentes règles de mise en correspondance, y compris quelques-unes des méthodes standards de classification supervisée pour effectuer la reconnaissance des mots visuels pendant la phase de test. Nous évaluons ces différentes stratégies dans les deux étapes. Afin d'assurer la robustesse aux variations de pose entre images d'apprentissage et images de test, nous explorons différentes façons d'intégrer les descripteurs SIFT extraits de vues synthétiques générées à partir des images d'apprentissage. Nous proposons également une stratégie d'accélération exacte pour l'algorithme mean-shift
Origine | Fichiers produits par l'(les) auteur(s) |
