Probabilistic analysis of real-time systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Analyse probabiliste des systèmes temps réel
Dorin Maxim
  • Fonction : Auteur
  • PersonId : 950359
Critical real-time embedded systems integrate complex architectures that evolve constantly in order to provide new functionality required by the end users of the systems (automotive, avionics, railway, etc). These new architectures have a direct impact on the variability of the timing behavior of the real-time system. This variability leads to important over-provisioning if the design of the system is based only on worst case reasoning. Probabilistic approaches propose solutions are based on the probability of occurrence of the worst case values in order to avoid over provisioning while satisfying real-time constraints. The main objectives of this work are new analysis techniques for probabilistic real-time systems and ways of decreasing the complexity of these analyses, as well as to propose optimal xed priority scheduling algorithms for systems that have variability at the level of execution times. The results that we provide in this work have been proved applicable to hard real-time systems, which are the main focus of our work. Our proposed analysis for systems with multiple probabilistic parameters has been shown to greatly decrease the pessimism introduced by other types of analyses. This type of analysis combined with the proper optimal scheduling algorithms for probabilistic real-time system help the system designers to better appreciate the feasibility of a system, especially of those that are deemed unfeasible by deterministic analyses/scheduling algorithms.
Les systèmes embarqués temps réel critiques intègrent des architectures complexes qui évoluent constamment a n d'intégrer des nouvelles fonctionnalités requises par les utilisateurs naux des systèmes (automobile, avionique, ferroviaire, etc.). Ces nouvelles architectures ont un impact direct sur la variabilité du comportement temporel des systèmes temps réel. Cette variabilité entraîne un sur-approvisionnement important si la conception du système est uniquement basée sur le raisonnement pire cas. Approches probabilistes proposent des solutions basées sur la probabilité d'occurrence des valeurs les plus défavorables a n d'éviter le sur-approvisionnement, tout en satisfaisant les contraintes temps réel. Les principaux objectifs de ce travail sont de proposer des nouvelles techniques d'analyse des systèmes temps réel probabilistes et des moyens de diminuer la complexité de ces analyses, ainsi que de proposer des algorithmes optimaux d'ordonnancement á priorité xe pour les systèmes avec des temps d'exécution décrits par des variables aléatoires. Les résultats que nous présentons dans ce travail ont été prouvés surs et á utiliser pour les systèmes temps réel durs, qui sont l'objet principal de notre travail. Notre analyse des systèmes avec plusieurs paramètres probabilistes a été démontrée considérablement moins pessimiste que d'autres types d'analyses. Cette analyse combinée avec des algorithmes d'ordonnancement optimaux appropriées pour les systèmes temps réel probabilistes peut aider les concepteurs de systèmes á mieux apprécier la faisabilité d'un systéme, en particulier de ceux qui sont jugé irréalisable par des analyses/algorithmes d'ordonnancement déterministes.
thesis_Dorin_MAXIM.pdf (2.01 Mo) Télécharger le fichier
tel-01750613 , version 2 (01-01-2014)
tel-01750613 , version 3 (04-01-2014)
tel-01750613 , version 1 (29-03-2018)
  • HAL Id : tel-01750613 , version 3
Dorin Maxim. Probabilistic analysis of real-time systems. Embedded Systems. Université de Lorraine, 2013. English. ⟨NNT : ⟩. ⟨tel-01750613v3⟩
445 Consultations
380 Téléchargements
