Towards scalable, multi-view urban modeling using structure priors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Vers une modélisation urbaine 3D extensible intégrant des à priori de structure géométrique
Amine Bourki
  • Fonction : Auteur
  • PersonId : 1094219
In this thesis, we address the problem of 3D reconstruction from a sequence of calibrated street-level photographs with a simultaneous focus on scalability and the use of structure priors in Multi-View Stereo (MVS).While both aspects have been studied broadly, existing scalable MVS approaches do not handle well the ubiquitous structural regularities, yet simple, of man-made environments. On the other hand, structure-aware 3D reconstruction methods are slow and scale poorly with the size of the input sequences and/or may even require additional restrictive information. The goal of this thesis is to reconcile scalability and structure awareness within common MVS grounds using soft, generic priors which encourage : (i) piecewise planarity, (ii) alignment of objects boundaries with image gradients and (iii) with vanishing directions (VDs), and (iv) objects co-planarity. To do so, we present the novel “Patchwork Stereo” framework which integrates photometric stereo from a handful of wide-baseline views and a sparse 3D point cloud combining robust 3D plane extraction and top-down image partitioning from a unified 2D-3D analysis in a principled Markov Random Field energy minimization. We evaluate our contributions quantitatively and qualitatively on challenging urban datasets and illustrate results which are at least on par with state-of-the-art methods in terms of geometric structure, but achieved in several orders of magnitude faster paving the way for photo-realistic city-scale modeling
Nous étudions dans cette thèse le problème de reconstruction 3D multi-vue à partir d’une séquence d’images au sol acquises dans des environnements urbains ainsi que la prise en compte d’a priori permettant la préservation de la structure sous-jacente de la géométrie 3D observée, ainsi que le passage à l’échelle de tels processus de reconstruction qui est intrinsèquement délicat dans le contexte de l’imagerie urbaine. Bien que ces deux axes aient été traités de manière extensive dans la littérature, les méthodes de reconstruction 3D structurée souffrent d’une complexité en temps de calculs restreignant significativement leur intérêt. D’autre part, les approches de reconstruction 3D large échelle produisent généralement une géométrie simplifiée, perdant ainsi des éléments de structures qui sont importants dans le contexte urbain. L’objectif de cette thèse est de concilier les avantages des approches de reconstruction 3D structurée à celles des méthodes rapides produisant une géométrie simplifiée. Pour ce faire, nous présentons “Patchwork Stereo”, un framework qui combine stéréoscopie photométrique utilisant une poignée d’images issues de points de vue éloignés, et un nuage de point épars. Notre méthode intègre une analyse simultanée 2D-3D réalisant une extraction robuste de plans 3D ainsi qu’une segmentation d’images top-down structurée et repose sur une optimisation par champs de Markov aléatoires. Les contributions présentées sont évaluées via des expériences quantitatives et qualitatives sur des données d’imagerie urbaine complexes illustrant des performances tant quant à la fidélité structurelle des reconstructions 3D que du passage à l’échelle
TH2017PESC1062.pdf (83.97 Mo) Télécharger le fichier
tel-01786911 , version 1 (07-05-2018)
  • HAL Id : tel-01786911 , version 1
Lien texte intégral
Amine Bourki. Towards scalable, multi-view urban modeling using structure priors. Modeling and Simulation. Université Paris-Est, 2017. English. ⟨NNT : 2017PESC1062⟩. ⟨tel-01786911⟩
244 Consultations
60 Téléchargements
