Etude expérimentale d’une interaction thermique au sein d’un fluide - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Experimental study of a solid/liquid thermal interaction
During a reactivity insertion accident, the temperature and the pressure rapidly increase inside the rod and can lead to the rupture of the clad and the ejection of fuel toward the coolant. Since the fuel could be finely fragmented, the thermal interaction between fuel and coolant (FCI) could create a pressure wave as well as a large vapor volume. Safety-related consequences of the FCI may be related to both phenomena. Past experimental studies concerning such a RIA related FCI are in-pile experiments in thermal hydraulics conditions that differ from PWR conditions. Therefore validation of a simulation tool from these data and extrapolation to reactors conditions is subject to uncertainties. This experimental study is devoted to the violent thermal interaction between a hot material and a fluid. An experimental bench has been designed. It is mainly a cylindrical tube, where the interaction takes place, connected to a larger vessel as a compressibility tank. To reduce the required level of energy as well as temperature and pressure conditions, liquid carbon dioxide has been chosen to simulate water in PWR conditions. Respect of thermodynamics similarity criteria allows to lower pressure by a factor 3 and energy per unit mass fluid by a factor 5. To produce the energy pulse, a tungsten wire is heated by Joule effect from the discharge of a 27 mF capacity. Design of the tank allows for a relatively long mechanical relaxation of the coolant with regards to the heat transfer kinetics. The pressure wave is recorded thanks to four dynamic pressure sensors along the tube. Two dual tip fiber optical probes allow characterizing the kinetics of vapor formation near the wire. The data acquisition system operates with a required frequency of the MHz range. This test bench allows to record the local behavior of the fluid such as the pressurization of the liquid. A very clear pressure wave have been recorded just after weak energy pulse around 0.2 kJ. The influence of some major parameters on these quantities have been studied. For example, the liquid level in the tank is increased between two tests up to be totally fu ll, so, the influence of the compressibility is highlighted. Also, three different wire diameters have been used to modify the heat transfer kinetics. Finally, several intensities of the energy pulse have been considered. All these studies help to improve the understanding on the thermal interaction potentially involved in the nuclear reactor safety context.
Un accident d’insertion de réactivité (RIA) dans un cœur nucléaire pourrait provoquer la rupture d’une gaine et l’éjection d’une fine poudre de combustible chaud dans le caloporteur. La réponse du fluide peut être violente. L’étude de cette interaction (Fuel/Coolant Interaction FCI) est importante pour la sûreté nucléaire. Plusieurs études et expériences ont été menées avec de l’eau ou du sodium ou sont prévues dans le cadre des essais intégraux du programme international dans le réacteur CABRI. Cependant, les conditions complexes ne permettent pas la mesure des grandeurs locales nécessaires à l’étude de la dynamique de vaporisation. En effet, effectuer des expériences de vaporisation violente avec de l’eau requiert beaucoup d’énergie et des équipements résistant aux hautes pressions, notamment pour reproduire les conditions de fonctionnement d’une centrale nucléaire de type REP. Il est ainsi intéressant d’utiliser un autre fluide, tel que le dioxyde de carbone, dont les propriétés thermodynamiques (pression critique, enthalpie de vaporisation...) réduisent ces contraintes. Néanmoins, afin de pouvoir comparer et utiliser les observations de l’expérience, il est indispensable d’établir et de vérifier des lois de similitudes entre les deux fluides. L’étude de ces similarités entre l’eau et le dioxyde de carbone a établi qu’en conservant la pression réduite ainsi que le titre thermodynamique, on obtient des rendements similaires pour la conversion de l’énergie thermique en travail avec des énergies mises en jeu divisées par cinq. Ceci a permis d’envisager la conception et la réalisation d’un banc d’essais pour provoquer l’interaction thermique violente au sein d’un fluide. Afin de reproduire la cinétique de l’interaction, la géométrie du système a été adaptée. L’impulsion d’énergie au sein du fluide est générée à l’aide d’un filament de tungstène subissant la décharge d’une batterie de condensateurs à l’extrémité basse d’un cylindre. Au-dessus de ce cylindre, un réservoir de grand volume offre une source de compressibilité. L’enceinte contenant le CO2 liquide aux conditions thermodynamiques adaptables est instrumentée à l’aide de capteurs de pression le long du tube et des sondes optiques pour repérer la phase vapeur. Ce banc expérimental a permis d’acquérir des observations locales de la réaction telle que la montée en pression du liquide. Un pic de pression franc a été observé pour des impulsions d’énergie relativement faible, de l’ordre de 0,2 kJ. Plusieurs études sur les paramètres d’influences ont été menées. Notamment, l’influence de l’énergie, du diamètre du fil et du sous-refroidissement.
these.pdf (8.21 Mo) Télécharger le fichier
tel-02063316 , version 1 (11-03-2019)
  • HAL Id : tel-02063316 , version 1
Adrien Abbate. Etude expérimentale d’une interaction thermique au sein d’un fluide. Thermique [physics.class-ph]. Université de Lyon, 2018. Français. ⟨NNT : 2018LYSEI001⟩. ⟨tel-02063316⟩
223 Consultations
90 Téléchargements
