Mesenchymal stem cells reduce hypoxia-induced apoptosis in alveolar epithelial cells by modulating HIF and ROS hypoxic signalings
Caractérisation de l'effet cytoprotecteur des cellules souches mésenchymateuses sur l'apoptose et sur les altérations phénotypiques des cellules épithèliales alvéolaires soumises à l'hypoxie
Acute or chronic alveolar injuries provoke massive apoptosis of alveolar epithelial cells (AEC) that compromises an efficient repair of the alveolar epithelium and leads to lung diseases such as ARDS or IPF. These disorders are commonly associated with local alveolar hypoxia aggravating their progression through the stimulation of AEC apoptosis. Administration of allogenic mesenchymal stem cells (MSCs) has been shown to limit lung inflammation and fibrosis in murine models of alveolar injury, through a still poorly understood paracrine mechanism. In a first study, we showed that long term exposure of AEC in hypoxia leads to phenotypic alterations which looks like epithelio-mesenchymal transition (EMT). Co-culture with MSCs prevent hypoxia-induced EMT.In a second work, we studied whether MSC could protect AEC from hypoxia-induced apoptosis and the mechanisms involved. hMSC-conditioned media (hMSC-CM) significantly reduced hypoxia-induced apoptosis of AEC. Such a anti-apoptotic effect was also obtained with ROS scavenger N-acetylcystein or HIF1a inhibitor YC-1. hMSC-CM decreased the protein expression of HIF1α and HIF2α and of their pro-apoptotic target Bnip3 in hypoxic AEC. hMSC-CM also reduced ROS accumulation in hypoxic AEC by enhancing the activity of anti-oxidant enzymes and prevented the induction of CHOP, a pro-apoptotic factor induced by ROS signaling. The paracrine effect of hMSC was partly dependent on KGF and HGF secretion. hMSC prevent via a paracrine effect hypoxia-induced apoptosis of AEC by modulating hypoxic and ROS signaling.These two studies show that MSCs exert cytoprotective effects in vitro against hypoxia-induced apoptosis and EMT in AEC
La fibrose pulmonaire idiopathique (FPI) et le syndrome de détresse respiratoire aiguë (SDRA) de l’adulte constituent des affections sévères du poumon distal, avec un pronostic sombre pour les patients. A ce jour, aucun traitement n’est réellement efficace. De manière intéressante, une hypoxie alvéolaire est retrouvée dans ces pathologies.La thérapie cellulaire utilisant des cellules souches mésenchymateuses humaines (CSMh) pourrait représenter un intérêt thérapeutique chez l’Homme. Cependant, leurs mécanismes d’action sont multiples et encore mal définis. Aussi, nous avons testé in vitro l’hypothèse selon laquelle les CSMh pourraient exercer un effet cytoprotecteur paracrine sur les cellules épithéliales alvéolaires (CEA) soumises à l’hypoxie.Dans une première étude, nous avons montré qu’une exposition prolongée à l’hypoxie telle que celle rencontrée au cours de la FPI induisait des modifications phénotypiques des CEA primaires de rat, évocatrices d’une transition épithélio-mésenchymateuse (TEM). On observe une perte progressive d’expression des marqueurs épithéliaux (TTF1, AQP5, ZO-1 et E-Cadhérine), couplée à l’apparition tardive de marqueurs mésenchymateux (α-SMA et Vimentine). Ces modifications phénotypiques s’accompagnent de l’expression dès les premières heures d’hypoxie de facteurs de transcription impliqués dans la TEM (SNAI1, TWIST1 et ZEB1) ou induits par l’hypoxie (HIF-1α et HIF-2α), et de protéines induisant la TEM (TGF-β1 et CTGF). La co-culture des CEA avec des CSMh en fond de puits prévient les modifications phénotypiques induites par l’hypoxie ainsi que l’expression des facteurs pro-TEM TWIST1, ZEB1, TGF-β1 et CTGF. Cet effet bénéfique des CSM est en partie expliqué par la sécrétion d’un facteur de croissance épithélial, le KGF.Dans une deuxième étude, nous avons confirmé que les CEA entraient en apoptose en condition hypoxique, via l’induction de deux voies de signalisations hypoxiques pro-apoptotiques. D’une part, les facteurs de transcription induits par l’hypoxie HIF sont stabilisés, et une cible pro-apoptotique, Bnip3, est induite. D’autre part, l’hypoxie induit une accumulation d’espèces réactives à l’oxygène délétère pour la cellule, perturbant l’équilibre redox de la cellule, endommageant l’ADN, et conduisant à l’apoptose. Cette accumulation pourrait résulter notamment d’une diminution de l’activité des enzymes anti-oxydantes SOD, en hypoxie. Le manque d’oxygène entraine également l’expression de CHOP, facteur de transcription pro-apoptotique impliqué dans le stress du réticulum endoplasmique, qui va13inhiber l’expression de la protéine anti-apoptotique Bcl-2. Nous avons montré que la culture des CEA en présence de milieu conditionné de CSMh (mc-CSMh) permet de prévenir partiellement l’apoptose des CEA en hypoxie, en modulant la voie de signalisation HIF, et en prévenant l’accumulation et les effets délétères des ROS. L’effet protecteur des CSM impliquerait le KGF comme observé lors de la première étude, mais également le HGF.Ces deux études indiquent que les CSMh sont susceptibles d’exercer des effets cytoprotecteurs paracrines vis-à-vis des CEA soumises à l’hypoxie aiguë ou prolongée, en limitant d’une part les modifications phénotypiques évocatrices de TEM, et d’autre part l’apoptose des CEA via la modulation des voies de signalisations hypoxiques. La sécrétion par les CSMh de KGF et de HGF, facteurs de croissance épithéliaux connus pour leurs effets bénéfiques sur les CEA, explique en partie les effets protecteurs paracrines des CSMh. Nos résultats suggèrent que les effets cytoprotecteurs des CSMh vis-à-vis des CEA pourraient contribuer aux effets bénéfiques des CSMh observés in vivo dans différents modèles animaux de fibrose induite, ou lors d’agressions alvéolaires aiguës.
