Desing and evaluation of interaction techniques for exploring complexe data in large display-spaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Conception et évaluation de techniques d'interaction pour l'exploration de données complexes dans de larges espaces d'affichage
Today's ever-growing data is becoming increasingly complex due to its large volume and high dimensionality: it thus becomes crucial to explore interactive visualization environments that go beyond the traditional desktop in order to provide a larger display area and offer more efficient interaction techniques to manipulate the data. The main environments fitting the aforementioned description are: large displays, i.e. an assembly of displays amounting to a single space; Multi-display Environments (MDEs), i.e. a combination of heterogeneous displays (monitors, smartphones/tablets/wearables, interactive tabletops...) spatially distributed in the environment; and immersive environments, i.e. systems where everything can be used as a display surface, without imposing any bound between displays and immersing the user within the environment. The objective of our work is to design and experiment original and efficient interaction techniques well suited for each of the previously described environments. First, we focused on the interaction with large datasets on large displays. We specifically studied simultaneous interaction with multiple regions of interest of the displayed visualization. We implemented and evaluated an extension of the traditional overview+detail interface to tackle this problem: it consists of an overview+detail interface where the overview is displayed on a large screen and multiple detailed views are displayed on a tactile tablet. The interface allows the user to have up to four detailed views of the visualization at the same time. We studied its usefulness as well as the optimal number of detailed views that can be used efficiently. Second, we designed a novel touch-enabled device, TDome, to facilitate interactions in Multi- display environments. The device is composed of a dome-like base and provides up to 6 degrees of freedom, a touchscreen and a camera that can sense the environment. [...]
Les données d'aujourd'hui deviennent de plus en plus complexes à cause de la forte croissance de leurs volumes ainsi que leur multidimensionnalité. Il devient donc nécessaire d'explorer des environnements d'affichage qui aillent au-delà du simple affichage de données offert par les moniteurs traditionnels et ce, afin de fournir une plus grande surface d'affichage ainsi que des techniques d'interaction plus performantes pour l'exploration de données. Les environnements correspondants à cette description sont les suivants : Les écrans large ; les environnements multi-écrans (EME) composés de plusieurs écrans hétérogènes spatialement distribués (moniteurs, smartphones, tablettes, table interactive ...) ; les environnements immersifs. Dans ce contexte, l'objectif de ces travaux de thèse est de concevoir et d'évaluer des solutions d'interaction originales, efficaces et adaptées à chacun des trois environnements cités précédemment. Une première contribution de nos travaux consiste en Split-focus : une interface de visualisation et d'interaction qui exploite les facilités offertes par les environnements multi-écrans dans la visualisation de données multidimensionnelles au travers d'une interface overview + multi-detail multi-écrans. Bien que plusieurs techniques d'interaction offrent plus d'une vue détaillée en simultané, le nombre optimal de vues détaillées n'a pas été étudié. Dans ce type d'interface, le nombre de vues détaillées influe grandement sur l'interaction : avoir une seule vue détaillée offre un grand espace d'affichage mais ne permet qu'une exploration séquentielle de la vue d'ensemble?; avoir plusieurs vues détaillées réduit l'espace d'affichage dans chaque vue mais permet une exploration parallèle de la vue d'ensemble. Ce travail explore le bénéfice de diviser la vue détaillée d'une interface overview + detail pour manipuler de larges graphes à travers une étude expérimentale utilisant la technique Split-focus. Split-focus est une interface overview + multi-détails permettant d'avoir une vue d'ensemble sur un grand écran et plusieurs vues détaillées (1,2 ou 4) sur une tablette. [...]
2018TOU30252a.pdf (9.09 Mo) Télécharger le fichier
Origine Version validée par le jury (STAR)
tel-02329267 , version 1 (23-10-2019)
  • HAL Id : tel-02329267 , version 1
Houssem Eddine Saïdi. Desing and evaluation of interaction techniques for exploring complexe data in large display-spaces. Human-Computer Interaction [cs.HC]. Université Paul Sabatier - Toulouse III, 2018. English. ⟨NNT : 2018TOU30252⟩. ⟨tel-02329267⟩
152 Consultations
279 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
