ANALYSE DU RISQUE D'INONDATION EN CAS DE RUPTURE DES BARRAGES D'AYAME 1 ET 2 DANS LE DEPARTEMENT D'ABOISSO (SUD-EST COTE D'IVOIRE) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2022
ANALYSIS OF THE FLOOD RISK IN CASE OF DAM FAILURE OF AYAME 1 AND 2 IN THE DEPARTMENT OF ABOISSO (SOUTHEAST COTE D'IVOIRE)
Hydroelectric dams are sometimes very imposing infrastructures on the course of a watercourse. These structures, although useful for the production of energy necessary for development, can also endanger the populations installed downstream of their reservoirs. The greatest fear for these inhabitants would be to see the water from the reservoir of a dam that has just broken. In the department of Aboisso in the south-east of Côte d'Ivoire, the Ayamé 1 and 2 hydroelectric dams were built on the Bia River. Downstream of these structures, which retain nearly 1,000,000,000 m3 of water, are localities such as Ayamé, Koukourandoumi, Aboisso, Aliékro which contain important stakes in a valley regularly flooded by rising waters. The impacts of flooding related to river floods in the wet season or during dam spills are considerable, but remain far from the consequences that a rupture of these dams could cause. The rupture of the dams being more devastating, this work aims to analyze the risk of flooding that such a situation could induce downstream of the dams of Ayamé 1 and 2. In particular, this work made it possible to assess the flow impacts of the Ayamé 1 reservoir and to know the extent of the flood downstream in the event of a rupture of these structures. To conduct this study, GIS is used to bring out the digital terrain model and the river network essential to the knowledge of hazards. On these physical elements is then superimposed the layer of issues present in the department of Aboisso. This combination of hazards and challenges made it possible to determine the flood risk area downstream of the dams. Another approach was to simulate the rupture of dams with HEC-RAS. The results of the model are then integrated into ArcGis to make the flood maps. The simulation reveals a flood over a distance of 21.6 km from Ayamé to Aboisso. On this scale as in the department, villages will be affected, plantations and crops will be destroyed and forests invaded by water. But Aboisso remains the most affected site in the event of a disaster, which will make it impossible to transport land between Côte d'Ivoire and Ghana by the A100 international road.
Les barrages hydroélectriques sont des infrastructures parfois très imposantes sur le parcours d’un cours d’eau. Ces ouvrages, bien que utiles pour la production d’énergie nécessaire au développement, peuvent aussi mettre en danger les populations installées en aval de leurs réservoirs. La plus grande crainte pour ces habitants serait de voir déferler sur eux l’eau du réservoir d’un barrage qui vient de rompre. Dans le département d’Aboisso au Sud-Est de la Côte d’Ivoire, les barrages hydroélectriques d’Ayamé 1 et 2 ont été construits sur le fleuve Bia. En aval de ces ouvrages qui retiennent près de 1 000 000 000 m 3 d’eau, se trouvent des localités comme Ayamé, Koukourandoumi, Aboisso, Aliékro qui renferment d’importants enjeux dans une vallée régulièrement inondée par la montée des eaux. Les impacts des inondations liées aux crues du fleuve en saison humide ou pendant les déversements des barrages sont considérables, mais restent loin des conséquences qu’une rupture de ces barrages pourrait occasionner. La rupture des barrages étant plus dévastatrice, ce travail vise à analyser le risque d’inondation qu’une telle situation pourrait induire en aval des barrages d’Ayamé 1 et 2. De façon particulière, ce travail a permis d’apprécier les impacts d’écoulement de la retenue d’Ayamé 1 et de connaître l’étendu de l’inondation en aval en cas de rupture de ces ouvrages. Pour mener cette étude, le SIG est utilisé pour ressortir le modèle numérique de terrain et le réseau hydrographique essentiels à la connaissance des aléas. Sur ces éléments physiques est ensuite superposée la couche des enjeux présents dans le département d’Aboisso. Cette combinaison des aléas et des enjeux a permis de déterminer la zone à risque d’inondation en aval des barrages. Une autre démarche a consisté à simuler la rupture des barrages avec HEC-RAS. Les résultats du modèle sont ensuite intégrés à ArcGis pour réaliser les cartes d’inondation. La simulation révèle une inondation sur une distance de 21,6 km d’Ayamé à Aboisso. A cette échelle comme à celle du département, des villages seront touchés, des plantations et cultures seront détruites et des forêts envahis d’eau. Mais Aboisso reste le site le plus touché en cas de catastrophe, ce qui rendra impossible le transport terrestre entre la Côte d’Ivoire et le Ghana par la route internationale A100.
THESE_N'CHO LIONEL.pdf (12.18 Mo) Télécharger le fichier
tel-03994785 , version 1 (17-02-2023)
  • HAL Id : tel-03994785 , version 1
Ohoueu kikou Lionel Arnaud N'CHO. ANALYSE DU RISQUE D'INONDATION EN CAS DE RUPTURE DES BARRAGES D'AYAME 1 ET 2 DANS LE DEPARTEMENT D'ABOISSO (SUD-EST COTE D'IVOIRE). Sciences de l'Homme et Société. UNIVERSITE FELIX HOUPHOUET BOIGNY DE COCODY, 2022. Français. ⟨NNT : ⟩. ⟨tel-03994785⟩
169 Consultations
8 Téléchargements
