Analyse de la complexité institutionnelle de la collaboration public-privé au sein des projets d'équipements ludo-sportifs : le cas des concessions de travaux de centres aquatiques français - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2024
Analysis of the institutional complexity of public-private collaboration in leisure and sports facilities projects : the case of works concessions for French aquatic centres
In France, 83% of sports facilities are owned by local authorities, which must finance their renovation and adaptation to new leisure and health practices, in a context of growing budget constraints. As a result, they have developed collaborations with the private sector, which have recently taken the form of works concessions, whereby a consortium of private companies is delegated a global mission (financing, design, construction and operation-maintenance). This form of contractualisation redefines positions and strategies for the stakeholders involved in sports facilities projects. The aim of this thesis is therefore to analyse public-private collaboration in the context of sports facilities concession projects. This issue will be studied in particular in the context of aquatic centres concession projects, based on the concept of institutional logics (Thornton et al., 2012). Five French aquatic centre projects were investigated based on 31 semi-structured interviews supplemented by a corpus of documents for each case (n = 378).This research highlights the need for specific project skills, which must be managed as part of a broader project management approach. The results also raise questions about the notion of economic risk and the place of public service within these hybrid facilities (Richet et al., 2009), while putting into perspective the efficiency allowed by the globalisation of missions within a single contract.
En France, 83% du parc d’équipements sportifs appartient aux collectivités qui doivent en financer le renouvellement et l’adaptation à de nouvelles pratiques ludiques et hygiéniques, dans un contexte de contrainte budgétaire croissante. En conséquence, elles ont développé des collaborations avec le secteur privé qui ont récemment pris la forme des concessions de travaux, permettant de déléguer à un groupement d’entreprises privées une mission globale (financement, conception, construction et exploitation-maintenance). Cette forme de contractualisation redéfinit le positionnement et les stratégies des différents acteurs au sein des projets d’équipements sportifs. Dès lors, la problématique de cette thèse consiste à analyser les modalités de collaboration public-privé dans le cadre de projets de concession de travaux d’équipements sportifs. Cette question sera en particulier étudiée dans le cadre des projets de concession de centres aquatiques, à partir du concept de logiques institutionnelles (Thornton et al., 2012). Pour cela, cinq projets de centres aquatiques français ont été investigués à partir de 31 entretiens semi-directifs complétés par un corpus documentaire pour chaque cas (n = 378).Ce travail met en avant le besoin de compétences spécifiques sur les projets, dont la gestion doit s’inscrire dans une démarche plus large de management de projet. Les résultats permettent également de questionner la notion de risque économique ainsi que la place du service public au sein de ces équipements hybrides (Richet et al., 2009), tout en relativisant l’efficience permise par la globalisation des missions au sein d’un même contrat.
these_barbier_antoine.pdf (19.2 Mo) Télécharger le fichier
tel-04525168 , version 1 (28-03-2024)
  • HAL Id : tel-04525168 , version 1
Antoine Barbier. Analyse de la complexité institutionnelle de la collaboration public-privé au sein des projets d'équipements ludo-sportifs : le cas des concessions de travaux de centres aquatiques français. Education. Normandie Université, 2024. Français. ⟨NNT : 2024NORMR003⟩. ⟨tel-04525168⟩
0 Consultations
0 Téléchargements
