Valorisation des extrêmophiles dans le traitement des effluents salins et la production d'énergie par des systèmes bioélectrochimiques microbiens - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Theses Year : 2024
Valorisation of extremophiles in the treatment of salt effluents and energy production by microbial bioelectrochemical systems
Sirine Saadaoui
  • Function : Author
  • PersonId : 1375600
  • IdRef : 277087449
The textile industry generates large amounts of wastewater containing up to 80 g/L of NaCl and high concentrations of synthetic dyes. Azo dyes, which are toxic and persistent chemicals, are widely used in textile manufacturing. When discharged into water bodies, these dyes pose a significant threat to aquatic ecosystems and can also have implications for human health. To address this issue, several conventional physico-chemical methods have been implemented. However, these methods are not widely adopted primarily due to their high cost, the secondary pollution they generate, and their high energy consumption. Other anaerobic biological treatments have also been explored, but they often involve long decomposition periods with incomplete degradation. Additionally, exposure of microorganism cells to highly concentrated salt solutions can lead to significant water loss through osmosis, resulting in dehydration and potential cell death.The main objective of this thesis is to combine two methods, biological and electrochemical, within a single unit called a bioelectrochemical system (BES) to treat saline textile wastewater loaded with refractory azo dyes while generating energy in the form of electricity. This BES is distinguished by the use of halothermophilic electroactive bacteria from extreme Tunisian environments, which form bioanodes capable of tolerating saline stress. Parameters affecting the performance of the BES have been optimized, including the inoculum source, the presence of a co-substrate and its concentration, the electrode material and surface, and the applied potential to the working electrode. These optimizations were initially carried out using synthetic wastewater before being validated with real industrial wastewater. The obtained bioanodes were subject to comparative analysis using electrochemical, microscopic, analytical, and molecular tools. Additionally, reaction media were also examined using analytical and molecular tools.With synthetic wastewater, a maximum current density of 5.2 A/m2, a decolorization rate of 100 %, and a COD removal rate of 96 % were achieved. Moreover, with real wastewater, a maximum current density of 5.2 A/m2 was observed simultaneously with a decolorization rate of 93 % and a COD removal rate of 70 %. Thus, for the first time, the bacterial species Orenia metallireducens was identified in different matrices of the BES fueled with synthetic wastewater. This discovery suggests promising prospects for the degradation of azo dyes.
L’industrie textile génère de grandes quantités d'eaux usées contenant jusqu'à 80 g/L de NaCl et de fortes concentrations de colorants synthétiques. Les colorants azoïques, qui sont des produits chimiques toxiques et persistants, sont les plus largement utilisés dans la fabrication des textiles. Lorsqu'ils sont déversés dans les plans d'eau, ces colorants peuvent poser une menace significative pour les écosystèmes aquatiques, pouvant également avoir des répercussions sur la santé humaine. Pour remédier à cette problématique, plusieurs méthodes physico-chimiques conventionnelles ont été mises en œuvre. Ces méthodes ne sont pas largement adoptées principalement en raison de leur coût élevé, de la pollution secondaire qu’ils génèrent et de leur forte consommation d'énergie. D'autres traitements biologiques anaérobies ont été également explorées. Ces méthodes prennent de longues périodes de décomposition avec une dégradation souvent incomplète. De plus, si les cellules des microorganismes sont exposées à une solution très concentrée en sel, le phénomène d’osmose peut entraîner une perte d'eau intracellulaire significative, conduisant à la déshydratation et éventuellement à la mort cellulaire.L’objectif principal de cette thèse est de coupler deux méthodes biologique et électrochimique au sein d'une seule unité appelée système bioélectrochimique (SBE) en vue de traiter des eaux usées textiles salines chargées en colorants azoïques récalcitrants, tout en générant de l'énergie sous forme d'électricité. Ce SBE se distingue par l'utilisation de bactéries électroactives halothermophiles provenant des environnements extrêmes tunisiens, lesquelles forment des bioanodes capables de tolérer le stress salin. Les paramètres impactant les performances du SBE ont été optimisés, notamment la source d'inoculum, la présence d’un co-substrat et sa concentration, le matériau de l'électrode ainsi que sa surface et le potentiel appliqué à l'électrode de travail. Ces optimisations ont été réalisées initialement à partir d’eaux usées synthétiques avant d'être validées avec des eaux usées industrielles réelles. Les bioanodes obtenues ont fait l'objet d'une analyse comparative à l'aide d'outils électrochimiques, microscopiques, analytiques et moléculaires. En complément, les milieux réactionnels ont également été examinés à l'aide d'outils analytiques et moléculaires.Avec des eaux usées synthétiques, une densité de courant maximale de 5,2 A/m2, un taux de décoloration de 100 % et un taux d’élimination de la DCO de 96 % ont été obtenus. Par ailleurs, avec les eaux usées réelles, la même densité de courant maximal 5,2 A/m2 a été observée simultanément avec un taux de décoloration de 93 % et un taux d’abattement de la DCO de 70 %. Ainsi, pour la première fois, l’espèce bactérienne Orenia metallireducens a été identifiée dans les différentes matrices du SBE alimenté avec des eaux usées synthétiques. Cette découverte suggère des perspectives prometteuses pour la dégradation des colorants azoïques.
Sirine_SAADAOUI2.pdf (3.16 Mo) Télécharger le fichier
Origin : Version validated by the jury (STAR)
Dates and versions
tel-04548893 , version 1 (16-04-2024)
Identifiers
  • HAL Id : tel-04548893 , version 1
Cite
Sirine Saadaoui. Valorisation des extrêmophiles dans le traitement des effluents salins et la production d'énergie par des systèmes bioélectrochimiques microbiens. Génie des procédés. Université de Toulouse; École nationale d'ingénieurs de Tunis (Tunisie), 2024. Français. ⟨NNT : 2024TLSEP008⟩. ⟨tel-04548893⟩
56 View
37 Download
Share
