Intégration de MEMS pour la réalisation d’ une antenne spirale à hautes performances reconfigurable - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
MEMS integration for the design of high performance reconfigurable spiral antenna
Jérôme Massiot
  • Fonction : Auteur
  • PersonId : 1375833
  • IdRef : 17744374X
The evolution of radar and telecommunication systems needs antennas, which are able to adapt their performances in real time. Reconfigurable antennas can provides such characteristics through a reconfiguration of the frequency of operation, the polarisation or the radiation patterns. Besides, MEMS switches present attractive assets for reconfiguring a radiating element as they consume low power and have low losses. The thesis is about the integration of MEMS within an ultra wide band spiral antenna. The objectives of the thesis are: • To master the integration of packaged MEMS in an antenna • To reconfigure the spiral antenna for the achievement of a band rejection • To manufacture some prototypes and carry out experimental validations The radiation property of the spiral antenna has been studied. A reconfiguration of the spiral, which consists of inserting added elements within the radiating structure, has been investigated and applied. Spiral antennas with and without the reconfiguration mechanism have been manufatured and tested. The basic spiral antenna (without the reconfiguration mechanism) presents interesting properties: ultra wide band characteristics from 4 to 20 GHz, a relatively high gain of 5 to 9 dBi, and a low profile thickness of 3.5 mm. In practice, the achieved rejection has been difficult to prove due to the difficulties related to the integration of the packaged MEMS.
L'émergence de nouveaux systèmes de radar et de télécommunication nécessite des antennes adaptables en temps réel. Les antennes reconfigurables permettent de répondre à ce besoin par le biais d'une reconfiguration en fréquence, en polarisation ou en diagramme de rayonnement. En outre, les switchs MEMS sont des composants particulièrement attrayants pour reconfigurer une antenne car ils consomment peu et ont de faibles niveaux de pertes. La thèse porte sur l'intégration de MEMS dans une antenne spirale ultra large bande; les objectifs étant : • maitriser l'intégration de MEMS packagés dans une antenne ; • reconfigurer la spirale pour rejeter les fréquences en dehors de la bande utile ; • réaliser des prototypes et effectuer des validations expérimentales. Le mécanisme de rayonnement d'une spirale a été étudié pour identifier les possibilités de reconfiguration de l'élément rayonant. L'une d'elles a été étudiée et mise en œuvre en ajoutant des éléments au cœur de l'antenne spirale. Des antennes spirales avec et sans mécanismes de reconfiguration ont été réalisées et testées. L'antenne de base (sans résonateurs) présente des caractéristiques particulièrement intéressantes : fonctionnement sur la bande 4-20 GHz, gain relativement important de 5 à 9 dBi, et une faible épaisseur de 3.5 mm. La réjection obtenue en simulation s'est avérée difficile à prouver expérimentalement du fait des difficultés d'intégration de MEMS packagés sur l' antenne.
massiot.pdf (7.25 Mo) Télécharger le fichier
tel-04549877 , version 1 (17-04-2024)
  • HAL Id : tel-04549877 , version 1
Jérôme Massiot. Intégration de MEMS pour la réalisation d’ une antenne spirale à hautes performances reconfigurable. Micro et nanotechnologies/Microélectronique. Institut National Polytechnique de Toulouse - INPT, 2013. Français. ⟨NNT : 2013INPT0100⟩. ⟨tel-04549877⟩
0 Consultations
0 Téléchargements
