Conception intégrée par optimisation multicritère d’un système d’actionnement pour le conditionnement d’air d’un avion plus électrique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Integrated design by multiobjective optimization of an actuation system for air conditioning systems of a more electric aircraft
André De Andrade
  • Fonction : Auteur
  • PersonId : 1248401
  • IdRef : 172562562
The concept of More Electric Aircraft (MEA) implies new challenges especially due to the increase of the electrical embedded power. By this way, necessary improvements in terms of safety, energy efficiency and weight reduction are required. For this reason, the design of devices should be more approached with a view to the whole system than as separated elements. In order to facilitate power system integration and to ensure power quality aboard, this dissertation proposes an Integrated Optimal Design (IOD) of the input filter and the inverter feeding the High Speed Permanent Magnet Synchronous Motor (HSPMSM) by taking the flight mission into account. The Environmental Conditioning System (ECS) is equipped of the studied cabin air compressor with a rated power of 70 kW: a Multiobjective Genetic Algorithm (MOGA) is applied to achieve the CIO process. Considering the ECS as a whole, this thesis can be divided into three main parts: components sizing of the electromechanical conversion chain; local and sequential design of each system components (HSPMSM optimization loop followed by “voltage source inverter + input filter” optimization loop); simultaneous design of all system components (global optimization loop). Pareto-optimal solutions obtained from sequential and simultaneous design approaches are presented, analyzed and compared. Results clearly highlight the advantage of using a single optimization loop for the whole system in order to improve mass and efficiency.
Dans le contexte de l'avion plus électrique, de nouveaux défis technologiques apparaissent dans le développement des systèmes embarqués afin d'augmenter leur puissance électrique. Une optimisation visant la sécurité, l'efficacité énergétique et une diminution du volume et de la masse est ainsi nécessaire. A cet effet, les dispositifs doivent être considérés dans leur ensemble et non par éléments séparés. Pour faciliter l'intégration des systèmes de puissance et assurer la qualité du réseau de bord avion, cette thèse propose de tenir compte de la mission de vol et d'étudier la CIO « Conception Intégrée Optimale » du système complet comprenant le filtre d'entrée et l’onduleur de tension alimentant l'actionneur synchrone à aimants permanents haute vitesse « HSPMSM ». L'application est dédiée au système de conditionnement d'air cabine « ECS – Environmental Conditioning Systems » comprenant le compresseur d'air étudié, d'une puissance nominale de 70 kW. La thèse est structurée en trois parties principales: le dimensionnement des composants de la chaîne de conversion électromécanique ; la conception locale et séquentielle de chacun des composants du système (boucle d'optimisation actionneur puis boucle d'optimisation « onduleur de tension + filtre d'entrée » ; la conception simultanée de tous les composants du système (boucle d'optimisation globale). Les fronts « Pareto-optimaux » des solutions obtenues à partir des méthodes de conception séquentielles et simultanées sont présentés, analysés et comparés. Les résultats mettent clairement en évidence l'avantage d'utiliser une boucle d'optimisation unique pour l'amélioration de la masse et de l'efficacité énergétique du système.
de_andrade.pdf (14.98 Mo) Télécharger le fichier
tel-04550103 , version 1 (17-04-2024)
  • HAL Id : tel-04550103 , version 1
André De Andrade. Conception intégrée par optimisation multicritère d’un système d’actionnement pour le conditionnement d’air d’un avion plus électrique. Energie électrique. Institut National Polytechnique de Toulouse - INPT, 2013. Français. ⟨NNT : 2013INPT0145⟩. ⟨tel-04550103⟩
0 Consultations
0 Téléchargements
