Changements énergétiques et reconfigurations socio-spatiales dans le sud du Pérou - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2021
Energy changes and socio-spatial reconfigurations in southern Peru
Cambios energéticos y reconfiguraciones socio-espaciales en el sur del Perú
The discovery in the 1980s of important gas deposits in the province of Camisea in Cusco marks a major turning point in the history of the Peruvian energy system. The energy policy of the Peruvian state deviates from the imperative of a decarbonized energy transition, and, since the 2000s has focused on natural gas extracted from the national territory, in order to expand access to modern sources of energy and to secure its energy supply. An energy infrastructure mega-project, the South Peruvian Gas Pipeline, is oriented towards the southern regions, which resulted in the expansion of residential gas networks. This reorientation of the Peruvian energy system towards the use of natural gas poses many problems and challenges, including the problems related to the exploitation of this resource located in a fragile geographic area, the need to consolidate a national gas market that would motivate the deployment of a national gas network. Based on an approach combining the change of scale, the dimension of socio-spatial materiality and the relations between society and techniques, this thesis seeks to articulate the energy changes to the socio-spatial configurations that are in constant evolution. The method followed consists, on the one hand, in carrying out multi-site fieldwork in the south of Peru targeting by different large-scale energy programs, in order to observe these energy changes in different spaces, from institutions to homes. On the other hand, it relied on literature analysis and discourses to trace the genesis and evolution of the Peruvian energy system, which revealed the gradual construction of a consensus around natural gas. In addition, the use of cartographic and statistical methods attempted to capture the socio- spatial materiality of these energy changes. Thus, this thesis highlights the multi-scalar and multifaceted nature of energy changes in the Peruvian case, while proposing an approach that can be applied to other emerging countries.
En la década de los años 1980, el descubrimiento de grandes yacimientos de gas en la provincia de Camisea en Cusco marca un importante punto de inflexión en la historia del sistema energético del Perú. La política energética del Estado peruano se aleja del llamado a una transición energética libre de carbono y se ha centrado en el gas natural extraído en el territorio nacional desde la década de los años 2000, con el fin de ampliar el acceso a las fuentes de energía modernas y asegurar su suministro de energía. Un megaproyecto de infraestructura energética, el Gasoducto Sur Peruano, está orientado a las regiones del sur, que están experimentando la expansión de la red de distribución de gas para uso residencial. La reorientación del sistema energético peruano hacia el uso del gas natural plantea muchos problemas y desafíos, entre ellos la cuestión de la explotación de este recurso situado en una zona geográfica frágil, la necesidad de consolidar un mercado nacional de gas que motive el despliegue de una red nacional de gas y la adaptación de los territorios y poblaciones. Basada en un enfoque que combina el cambio de escala, la dimensión de las mate- rialidades socio-espaciales y la relación entre la sociedad y las técnicas, esta tesis trata de vincular los cambios energéticos con las configuraciones socio-espaciales en constante evolución. El método consistió, por un lado, en realizar un trabajo de campo en múltiples sitios del sur del Perú, al cual se dirigen diferentes programas energéticos de gran escala, para observar estos cambios energéticos en diferentes espacios, desde las instituciones hasta los hogares. Por otra parte, se basó en el análisis de la documentación y los diferentes dis- cursos para trazar el origen y la evolución del sistema energético peruano, que reveló la construcción gradual de un consenso en torno al gas natural. Además, con el uso de mé- todos cartográficos y estadísticos se intentó captar la materialidad socioespacial de estos cambios de energía. Así, esta tesis enfatizó el carácter multiescalar y multifacético de los cambios energéticos en el caso peruano, proponiendo al mismo tiempo un enfoque que po- dría aplicarse a otros países emergentes.
La découverte dans les années 1980 d’importants gisements gaziers, dans la province de Camisea à Cusco, marque un tournant majeur dans l’histoire du système énergétique péruvien. La politique énergétique de l’État péruvien déroge à l’impératif d’une transition énergétique décarbonée, et se focalise sur le gaz naturel extrait sur le territoire national depuis les années 2000, afin de diffuser l’accès à des sources modernes d’énergie et de sécuriser son approvisionnement énergétique. Un méga-projet d’infrastructure énergétique, le Gazoduc Sud Péruvien, est orienté vers les régions du sud, qui connaissent alors l’expansion des réseaux gaziers résidentiels. Ainsi, la réorientation du système énergétique péruvien vers l’usage du gaz naturel pose de nombreux problèmes et défis, notamment la question de l’exploitation de cette ressource localisée dans une zone géographique fragile, et la nécessité de consolider un marché gazier national. En nous appuyant sur une démarche associant le changement d’échelle, la dimension des matérialités socio-spatiales et des rapports entre société et techniques, cette thèse cherche à articuler les changements énergétiques aux configurations socio-spatiales en constante évolution. La méthode a consisté à mener des terrains multi-situés dans le sud du Pérou visé par différents programmes énergétiques de grande ampleur, pour observer ces changements énergétiques dans différents espaces, en allant des institutions jusqu’aux foyers. Elle a aussi reposé sur l’analyse de la documentation et les discours pour retracer la genèse et les évolutions du système énergétique péruvien, qui ont révélé la construction progressive d’un consensus autour du gaz naturel. En outre, l’utilisation de méthodes cartographiques et statistiques a tenté de saisir les matérialités socio-spatiales de ces changements énergétiques. Ainsi, cette thèse a mis en évidence le caractère multiscalaire et multifacette des changements énergétiques à partir du cas péruvien, tout en proposant une démarche qui pourra s’appliquer à d’autres pays émergents.
These_MONTESDEOCA_Nina_2021.pdf (339.14 Mo) Télécharger le fichier
tel-04550963 , version 1 (18-04-2024)
  • HAL Id : tel-04550963 , version 1
Nina Montes de Oca. Changements énergétiques et reconfigurations socio-spatiales dans le sud du Pérou. Géographie. Université de la Sorbonne nouvelle - Paris III, 2021. Français. ⟨NNT : 2021PA030020⟩. ⟨tel-04550963⟩
0 Consultations
0 Téléchargements
