Biosphere reserves : a response to reconcile urban development and biodiversity conservation? : Comparative experiences of urbanisation and protection in three biosphere reserves (Brazil, France, China).
Les réserves de biosphère : une réponse pour concilier développement urbain et conservation de la biodiversité ? : Expériences comparées d’urbanisation et de protection dans trois réserves de biosphères (Brésil, France Chine).
Urban development is an important driver of environmental change on a global scale, which has exerted enormous pressure on ecosystems thanks to rapidly changing population densities and displacement, particularly migration from rural to urban areas. In this context, in which conservation and development objectives have historically been antagonistic, nature reserves have emerged as the main global strategy for biodiversity conservation. In order to verify the limits and possibilities of reconciling environmental protection and urban development, this study used the perspective of socio-environmental assessment studies, focusing on the issue of relations between society and the environment in urbanization processes around biosphere reserves. In this sense, it identifies different points of intersection between the theme of urban planning experiences and the notion of sustainable development. In the comparative analysis of three biosphere reserve cases - Mata Atlântica (Brazil), Yancheng (China) and Camargue (France) - we examine the experience of occupying of the transition zones of these biosphere reserves, located in coastal areas. The case studies offer additional information to reinforce the hypothesis that the urban development process in transition zones of the reserves has involved the reinforcement of predatory social and ecological strategies of urban and peri-urban occupation. The socio-economic and socio-cultural fragmentation of nature and local communities has contributed to the intensification of environmental pollution indices and the reduction of biological productivity in coastal regions. Finally, the work recognized the importance of strengthening an integrated and participatory planning system capable of correcting and preventing the deterioration of the natural and built environment caused by urban and peri-urban ocupation. it is considered essential to open up interdisciplinary research efforts to explore alternative policies for the sector, such as ecotourism.
Le développement urbain est un important vecteur de la transformation de l'environnement à l’échelle mondiale, qui a provoqué énormes pressions sur les écosystèmes, en raison de l'évolution rapide des densités de population et des déplacements, et, en particulier, la migration des populations rurales vers les zones urbaines. Dans ce contexte, où les objectifs de conservation et de développement ont historiquement été antagonistes, les réserves naturelles sont apparues comme la principale stratégie mondiale de conservation de la biodiversité. Afin de vérifier les limites et les possibilités de concilier la protection de l'environnement et le développement urbain, cette étude a utilisé la perspective des études d'évaluation socio-environnementale, en se concentrant sur la question des relations entre la société et l'environnement dans les processus de urbanisation autour des réserves de biosphère. Dans ce sens, il identifie différents points d'intersection entre le thème de l’aménagement urbain et la notion de développement durable. Au cours de l'analyse comparative de trois cas de réserves de biosphère - Mata Atlântica (Brésil), Yancheng (Chine) et Camargue (France) - nous examinons l'expérience d'occupation des zones de transition de ces réserves de biosphère situées sur les zones côtières. Les études de cas apportent des informations supplémentaires qui permettent de renforcer l'hypothèse selon laquelle le processus de développement urbain dans les zones de transition des réserves a déclenché le renforcement des stratégies sociales et écologiques prédatrices de l'occupation urbaine et périurbaine. La fragmentation socioéconomique et socioculturelle de la nature et des communautés locales a contribué à l'intensification des indices de pollution de l'environnement et à la diminution de la productivité biologique dans les régions côtières. Enfin, les travaux ont reconnu l'importance du renforcement d'un système de planification intégrée et participative capable de corriger et de prévenir l'aggravation des réels foyers de détérioration de l'environnement naturel et bâti, induite par l’occupation urbaine et périurbaine. On considère qu’il est indispensable d’augmenter de l'effort de recherche interdisciplinaire pour la mise en place de politiques alternatives telle que l’écotourisme.
O desenvolvimento urbano é um importante motor da mudança ambiental em escala global, que tem exercido uma enorme pressão sobre os ecossistemas, graças à rápida mudança das densidades populacionais e deslocamentos, particularmente a migração das áreas rurais para as áreas urbanas. Neste contexto, em que os objetivos de conservação e de desenvolvimento tem sido historicamente antagônicos, as reservas naturais apresentam-se como a principal estratégia global de conservação da biodiversidade. A fim de verificar os limites e possibilidades de conciliar a proteção ambiental e o desenvolvimento urbano, neste estudo utilizou-se a perspectiva dos estudos de avaliação socioambiental, centrando-se na questão das relações entre a sociedade e o ambiente nos processos de urbanização em torno das reservas da biosfera. Nesse sentido, identifica diferentes pontos de intersecção entre o tema da planejamento urbano e a noção de desenvolvimento sustentável. Na análise comparativa dos três casos de Reservas da Biosfera - Mata Atlântica (Brasil), Yancheng (China) e Camargue (França) - examina a experiência de ocupação das áreas de transição dessas reservas biosfera, situadas em regiões costeiras. Os estudos de caso fornecem informações adicionais que reforçam a hipótese de que o processo de desenvolvimento urbano em zonas de transição das reservas envolvem o fortalecimento de estratégias sociais e ecológicas predatórias de ocupação urbana e periurbana. A fragmentação sócio-econômica e sociocultural da natureza e das comunidades locais tem contribuído à intensificação dos índices de poluição ambiental e a diminuição da produtividade em regiões costeiras. Finalmente, o trabalho reconheceu a importância de fortalecer um sistema de planejamento integrado e participativo que possa corrigir e prevenir o agravamento dos verdadeiros focos de deterioração do ambiente natural e construído induzido pela ocupação urbana e peri-urbana. Considera-se imprescindível a abertura do esforço de pesquisa interdisciplinar, para a exploração de políticas alternativas para o setor, como o ecoturismo. Palavras-chave: Urbanização, desenvolvimento urbano-turístico, ocupação periurbana, desenvolvimento sustentável, reservas da biosfera, ecoturismo
These_CARNEIRO_FERREIRA_Francisco_Antonio_2023.pdf (79.72 Mo)
Télécharger le fichier
