Les mécanismes de l’inhibition spatiale et non spatiale - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2023
Spatial and non-spatial inhibition mechanisms
While inhibition is often considered a uniform concept, inhibition abilities can be divided in many types: spatial inhibition and response inhibition. Spatial inhibition refers to the attenuation of the interference from locations containing salient and non-pertinent stimuli. For example, spatial inhibition guides visual search to limit the repeated visit of already explored locations. In contrast, response inhibition is motor-based and allows the adaptability of behaviour in a changing context when a movement must be prevented or altered. Although it is widely accepted that inhibition abilities can be divided in many types, such as spatial or response inhibition, the different mechanisms underlying them remain poorly understood and under-explored. The main aim of the present thesis was to explore the common and different mechanisms of spatial and response inhibition. Precisely, the mechanisms of suppression and enhancement during target selection were described during spatial inhibition. The alteration of spatial inhibition processes and the relative preservation of response inhibition abilities in patients with dorsal posterior parietal cortex lesions were also underlined. Finally, the specific contributions of the dorsal posterior parietal cortex for spatial and response inhibition were defined.
Bien que l’inhibition soit souvent considérée comme un concept uniforme, les habiletés d’inhibition se divisent en plusieurs types : l’inhibition spatiale et l’inhibition de réponse. L’inhibition spatiale réfère à l’atténuation de l’interférence de localisations contenant des stimuli saillants et non pertinents. Par exemple, l’inhibition spatiale guide la recherche visuelle de sorte à limiter la visite répétée de localisations déjà explorées. À l’opposé, l’inhibition de réponse est un processus de type moteur et permet l’adaptation du comportement à un contexte changeant lorsqu’un mouvement doit être altéré ou arrêté. Bien qu’il soit admis que les habiletés d’inhibition se subdivisent en plusieurs types, tel que l’inhibition spatiale et l’inhibition de réponse, les différents mécanismes les sous-tendant demeurent mal compris et sous explorés. L’objectif principal de la présente thèse était d’explorer les mécanismes communs et différents de l’inhibition spatiale et l’inhibition de réponse. Particulièrement, les mécanismes de suppression et de facilitation lors de la sélection de la cible furent décrits pour l’inhibition spatiale. De même, la perturbation des habiletés de l’inhibition spatiale et la préservation relative des habiletés d’inhibition de réponse à la suite à de lésions du cortex pariétal postérieur dorsal furent exemplifiées. Finalement, les apports spécifiques du cortex pariétal postérieur dorsal pour l’inhibition spatiale et l’inhibition de réponse furent définis.
TH2023OUERFELLIETHIERJULIE.pdf (6.33 Mo) Télécharger le fichier
tel-04559583 , version 1 (25-04-2024)
  • HAL Id : tel-04559583 , version 1
Julie Ouerfelli-Ethier. Les mécanismes de l’inhibition spatiale et non spatiale. Neurosciences. Université Claude Bernard - Lyon I; Université de Montréal (1978-..), 2023. Français. ⟨NNT : 2023LYO10134⟩. ⟨tel-04559583⟩
0 Consultations
0 Téléchargements
