Conséquences de la dérégulation de MET sur le phénotype des cancers bronchiques non à petites cellules EGFR mutés devenus résistants aux inhibiteurs de tyrosine kinase d’EGFR. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Consequences of MET dysregulation during EGFR Tyrosine Kinase Inhibitor resistance in EGFR mutated Non-Small Cell Lung Cancers
Introduction: Treatment of Epidermal Growth Factor Receptor (EGFR) mutated non-small cell lung cancers (NSCLC) relies on EGFR tyrosine kinase inhibitors (TKI). However, all patients treated with EGFR TKI eventually present tumor progression, due to mechanisms of resistance such as the MET amplification. There is currently no data on phenotypic changes induced by MET activation in this context. The objective of this thesis is to determine whether the MET amplification during EGFR TKI resistance in the EGFR mutated NSCLC induces a more aggressive phenotype in tumor cells and alters the natural history of the disease. Methods: Proliferation, anchorage independent growth, spheroid formation, anoïkis resistance and migration were studied in vitro in the HCC827 cell line, derived from an EGFR mutated NSCLC, and in its daughter cell line HCC827-GR6 (GR6) which became resistant to EGFR TKI through MET amplification. The expression of vimentin, ZEB1, and E-cadherin was evaluated in these cellular models in order to investigate an epithelial to mesenchymal transition (EMT) process induced by the MET amplification. In vivo, the tumor growth and the metastatic potential were analyzed by subcutaneous xenograft and intracardiac injection in mouse models. Finally, the clinical data of patients from 15 centers with a metastatic EGFR mutated NSCLC, exhibiting high MET overexpression in immunohistochemistry (score 3+) or MET amplification assessed by FISH on a re-biopsy performed after TKI EGFR progression were analyzed retrospectively. Results: In vitro, the MET amplification induced a significant increase in proliferation, anchorage independent growth, spheroid formation, anoïkis resistance and migration. Treatment with PHA-665752, a MET TKI, significantly reduced these biological properties in the GR6 cells harboring the MET amplification. An increase in the expression of vimentin and ZEB1 was also observed in the GR6 cells. In vivo, the MET amplification significantly increased the tumor growth and the metastatic potential. Treatment with crizotinib, another MET TKI, significantly decreased the metastatic potential of cells carrying MET amplification. Finally, patients with an EGFR mutated NSCLC, displayed a time to new metastases after TKI EGFR progression shorter than patients with high MET overexpression without MET amplification. Conclusion: The MET amplification during EGFR TKI resistance is associated in EGFR muted NSCLC with a more aggressive tumor phenotype. These results argue for the early use of MET inhibitors in combination with EGFR TKIs to avoid the emergence of a more aggressive resistant tumor clone.
Introduction : Le traitement des cancers bronchiques non à petites cellules (CBNPC) EGFR mutés repose sur les inhibiteurs de tyrosine kinase (ITK) du récepteur de l’Epidermal Growth Factor (EGFR). Cependant tous les patients traités par ITK EGFR finissent par présenter une progression tumorale, du fait de mécanismes de résistance comme l’amplification du gène codant pour le récepteur tyrosine kinase MET. Il n’existe actuellement aucune donnée sur les modifications phénotypiques induites par l’activation de MET dans ce contexte. L’objectif de cette thèse est de déterminer si l’amplification de MET, lors de la résistance aux ITK EGFR dans les CBNPC EGFR mutés, confère aux cellules tumorales un phénotype plus agressif et modifie l’histoire naturelle de la maladie. Méthodes : Les capacités de prolifération, de croissance sans ancrage, de formation de sphéroïdes, de résistance { l’anoïkis et de migration ont été étudiées in vitro dans la lignée HCC827, dérivée d’un CBNPC EGFR muté, et dans sa lignée fille HCC827-GR6 (GR6) devenue résistante aux ITK EGFR via une amplification du gène MET. L’expression de la vimentine, de ZEB1, et de la E-cadherine a également été étudiée dans les deux lignées cellulaires afin d’évaluer l’impact de l’amplification de MET sur la transition épithélio-mésenchymateuse (TEM). In vivo la croissance tumorale et le potentiel métastatique ont respectivement été analysés dans des modèles murins de xénogreffe ectopique et d’injection intracardiaque. Enfin les données cliniques de patients issus de 15 centres avec un CBNPC EGFR muté métastatique, présentant une forte surexpression de MET en immunohistochimie (score 3+) ou une amplification de MET en FISH sur une re-biopsie réalisée après la progression sous ITK EGFR ont été analysées rétrospectivement. Résultats : In vitro, l’amplification de MET induisait une augmentation significative de la prolifération, de la croissance sans ancrage, de la formation de sphéroïdes, de la résistance à l’anoïkis et de la migration. En présence d’un inhibiteur de MET, le PHA-665752, ces différentes propriétés biologiques étaient réduites de façon significative dans les cellules GR6 porteuses de l’amplification de MET. Il était également mis en évidence dans les cellules GR6 une augmentation de l’expression de la vimentine et de ZEB1. In vivo, l’amplification de MET augmentait significativement la croissance tumorale et le potentiel métastatique. Un traitement par crizotinib, ITK ciblant MET, diminuait de façon significative le potentiel métastatique des cellules porteuses de l’amplification de MET. Enfin les patients atteints d’un CBNPC EGFR muté, porteur d’une amplification de MET à la résistance { l’ITK EGFR, présentaient une durée jusqu’{ apparition de nouvelles métastases plus courte après progression sous ITK EGFR que les patients avec une forte surexpression de MET sans amplification génique. Conclusion L’amplification de MET dans un contexte de résistance aux ITK EGFR est associée à un phénotype tumoral plus agressif. Ces résultats plaident en faveur d’une utilisation précoce d’inhibiteurs de MET en association avec les ITK EGFR afin d’éviter l’émergence d’un clone tumoral résistant plus agressif.
Thèse simon Baldacci - 2017.pdf (3.82 Mo) Télécharger le fichier
tel-04559624 , version 1 (25-04-2024)
  • HAL Id : tel-04559624 , version 1
Simon Baldacci. Conséquences de la dérégulation de MET sur le phénotype des cancers bronchiques non à petites cellules EGFR mutés devenus résistants aux inhibiteurs de tyrosine kinase d’EGFR.. Cancer. Université de Lille 2, 2017. Français. ⟨NNT : ⟩. ⟨tel-04559624⟩
0 Consultations
0 Téléchargements
