Évaluation des impacts de l'occupation du sol sur la qualité des ressources en eau dans la région d'Akkar (nord du Liban) : le cas du territoire d'Al-Kayteh - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2023
Assessment of the impacts of land use on water resource quality in the Akkar region (northern Lebanon) : the case of the Al-Kayteh area
Akkar is a rural and economically deprived region located in northern Lebanon. It stands out as the second agricultural zone in Lebanon, where agriculture represents the primary sector of activity. Our study area, Al-Kayteh, covers 26% of the Akkar region's area and houses 60% of its population. It stretches from the Mediterranean coastline to the summit of Aarouba, reaching an elevation of 2230 meters, which is the highest point in Akkar.Al-Kayteh is currently facing significant yet disorganized urban development. However, this territory lacks urban planning documents or master plans governing its development and urbanization. Furthermore, most of its municipalities have outdated sewage systems or rely on septic tanks to treat wastewater. Moreover, the use of pesticides and chemical fertilizers in agricultural areas is not regulated. These factors pose a threat and exert pressure on the territory's water resources. Thus, Al-Kayteh, like Akkar, faces major challenges in terms of urban planning and water resource preservation.Previous studies on the quality of water resources in Akkar and Al-Kayteh have revealed that the majority of the region's water resources are contaminated, both microbiologically due to wastewater and chemically due to chemical fertilizers and pesticides. This is why we have approached the issue of water pollution in Akkar from a geographical and land-use planning perspective. This approach led us to examine land use patterns since 1962 on the ground, their evolution, and their impact on water resources.To contextualize the issue, we have examined the characteristics and problems of the water sector in Al-Kayteh, as well as the evolution and distribution of urbanization and types of agricultural activities in this area. Subsequently, 44 water samples (in wells and springs) were taken from different sectors of the area to characterize their quality and analyze the impacts of land use. Statistical methods were employed to identify relationships between different variables.The results obtained have enabled us to gain a better understanding of a still relatively unexplored area, the evolution of land use, and identifying sources of water resource pollution in the region. This will pave the way for the development of plans and master plans aimed at sustainable water resource management, as well as the planning of urban development and agriculture in the area.
Akkar est une région rurale et économiquement défavorisée, située au nord du Liban. L'agriculture en est le principal secteur d'activité, ce qui en fait la deuxième région agricole du Liban. Notre terrain d'étude, Al-Kayteh, couvre 26 % de la superficie de la région d'Akkar et abrite 60 % de sa population. Il s'étend depuis le littoral de la Méditerranée jusqu'au sommet d'Aarouba, le point le plus élevé d'Akkar culminant à 2230 mètres d'altitude.Al-Kayteh est actuellement confrontée à un développement urbain important mais désorganisé, ce territoire n'étant pas doté de documents d'urbanisme ni de plans directeurs régissant son aménagement. La plupart de ses communes disposent de réseaux d'égouts obsolètes ou utilisent des fosses septiques pour traiter les eaux usées et par ailleurs, l'utilisation de pesticides et d'engrais chimiques dans les zones agricoles n'est pas réglementé. Ces facteurs mettent en danger et exercent une pression sur les ressources en eau. Ainsi, Al-Kayteh, tout comme Akkar, doit relever des défis majeurs en matière d'aménagement urbain et de préservation des ressources en eau.Les études antérieures portant sur la qualité des ressources en eau à Akkar et à Al-Kayteh ont mis en lumière une pollution quasi-généralisée de cette ressource à l'échelle de la région, tant sur le plan microbiologique par les eaux usées que sur le plan chimique par les engrais chimiques et les pesticides. C'est pourquoi nous avons abordé la question de la pollution de l'eau à Akkar dans une perspective géographique et d'aménagement du territoire en identifiant les modalités de l'occupation du sol depuis 1962 et en en mesurant les conséquences sur les ressources en eau.Nous avons identifié les caractéristiques et les problèmes en relation avec le secteur de l'eau sur le territoire d'Al-Kayteh, ainsi que l'évolution et la répartition de l'urbanisation et des types d'activités agricoles. Des prélèvements ont été réalisés dans 44 puits et sources afin de déterminer la qualité de l'eau puis de caractériser, à l'aide d'outils statistiques, les impacts en lien avec l'occupation du sol.Les résultats obtenus ont permis de mieux appréhender un terrain encore peu prospecté, l'évolution de l'occupation du sol, et d'identifier les sources de pollution des ressources en eau dans la région. Ce travail pourra contribuer à l'élaboration de plans et de schémas directeurs visant à une gestion durable des ressources en eau, ainsi qu'à la planification du développement urbain et de l'agriculture sur le territoire.
Géographie
These_KAMALEDDINE_Ahmad.pdf (49.71 Mo) Télécharger le fichier
tel-04560370 , version 1 (26-04-2024)
  • HAL Id : tel-04560370 , version 1
Ahmad Kamaleddine. Évaluation des impacts de l'occupation du sol sur la qualité des ressources en eau dans la région d'Akkar (nord du Liban) : le cas du territoire d'Al-Kayteh. Géographie. Université de Lille; Université Libanaise, 2023. Français. ⟨NNT : 2023ULILA028⟩. ⟨tel-04560370⟩
0 Consultations
0 Téléchargements
