Musical proto-narratives in early mother-infantinteraction : a comparative study of French-Italian dyads - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2024
Les proto-narratifs musicaux dans l'interaction vocale mère-enfant : introduction d'un modèle communicationnel précoce dans une étude des dyades françaises et italiennes
Ebru Yilmaz
  • Fonction : Auteur
  • PersonId : 1378883
  • IdRef : 277276179
Narrative has been a major area of enquiry in many disciplines in the social sciences. Narrative organization is described in everyday conversation, written text and in various art forms. Proto-narratives occurring at an early period of infancy have also been described by various authors following previous narrative studies and some additional properties peculiar to this stage of life. Many studies show that, around the second month of life, infants become active participants in social interaction. In developmental psychology, research focused especially on the timing of vocalizations that characterize infants’ participation and on musical aspects, such as pitch variation and tempo, of mother-infant protoconversations. Such proto-narrative episodes have been carefully described in largely qualitative studies. The aim of this thesis is to systematically explore the narrative patterning of vocal protoconversational exchange between mothers and infants. Collections of narrative episodes were identified, coded and analyzed from 2 corpora of everyday naturalistic audio recordings of protoconversations between mothers and their 2-to-3 month-old infants from Paris and Verona. Comparisons between French and Italian samples were conducted in order to identify a minimal set of acoustic features for a rich description of protoconversational narrative. Comparisons between narrative and non narrative episodes were conducted to test the acoustic-based model of proto-narrative and to explore verbal content features. Results demonstrate that French and Italian narratives showed similar patterns in acoustic measures and similar amounts of infant participation. Results also showed different patterns of acoustic features, as well as different verbal content markers, between narrative and non narrative episodes. Furthermore, we found that infants spend more time vocalizing in narratives than in non narrative episodes. As a whole, this research provides evidence of an early communicational pattern in relaxed everyday adult-infant interaction. The implications of the narrative organisation of preverbal communication and its relation to musicality are discussed.
La narrativité est un sujet qui attire l’attention dans plusieurs domaines de sciences sociales. Ce motif particulier a été exprimé sous forme de conversation, écriture et expression artistique. La proto-narrativité de la vie précoce du bébé a été décrit par plusieurs auteurs suivant les études précédentes et en prenant en compte les particularités de cette période de la vie. Autour du deuxième mois de la vie, plusieurs études montrent que le bébé devient un participant actif dans l’interaction. En psychologie du développement, les recherches ont été conduites sur la qualité de vocalisations du bébé ou bien sur la musicalité de l’interaction mère-bébé. Etant décrit qualitativement, les formes narratives n’ont pas été étudiées quantitativement. Dans cette recherche présente, nous voulons étudier systématiquement comment cette narrative forme se produit dans les protoconversations vocales entre la mère et le bébé. Les enregistrements vocaux des seize dyades de Paris et de Vérone ont été analysés pour cette recherche. Cette analyse nous permet d’identifier une collection minimale des caractéristiques acoustiques pour décrire des narratifs protoconversationels. Ensuite, les mesures acoustiques et le contenu verbal du discours de la mère ont été étudiés en prenant en compte plusieurs aspects indiquant la forme narrative des épisodes narratifs et non-narratifs. Les résultats suggèrent que la comparaison des épisodes narratifs des italiens et français sur les mesures acoustiques et participation du bébé présente une forme similaire dans les deux cultures. Les patterns des épisodes narratifs de l’échantillon français diffèrent de ceux du groupe de non-narratif sur les mesures acoustiques et le contenu verbal. De plus, la contribution du bébé dans l’interaction est plus significative dans les épisodes narratifs. Dans l’ensemble, cette recherche suggère les prémices précoces d’un pattern interactionnel; une forme de pré-organisation qui prend forme autour de la musicalité partagée.
2024PA100016.pdf (37.92 Mo) Télécharger le fichier
tel-04561584 , version 1 (27-04-2024)
  • HAL Id : tel-04561584 , version 1
Ebru Yilmaz. Musical proto-narratives in early mother-infantinteraction : a comparative study of French-Italian dyads. Psychology. Université de Nanterre - Paris X, 2024. English. ⟨NNT : 2024PA100016⟩. ⟨tel-04561584⟩
0 Consultations
0 Téléchargements
