Data driven uncertainty quantification in macroscopic traffic flow models - 3IA Côte d’Azur – Interdisciplinary Institute for Artificial Intelligence Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We propose a Bayesian approach for parameter uncertainty quantification in macroscopic traffic flow models from cross-sectional data. We validate the results comparing the error metrics of both first and second order models. While involving more parameters to be calibrated, second order models globally show better performances in reconstructing traffic quantities of interest.
dduq_traffic.pdf (1.82 Mo) Télécharger le fichier
hal-03202124 , version 1 (19-04-2021)
hal-03202124 , version 2 (17-11-2021)
  • HAL Id : hal-03202124 , version 1
Alexandra Würth, Mickaël Binois, Paola Goatin, Simone Göttlich. Data driven uncertainty quantification in macroscopic traffic flow models. 2021. ⟨hal-03202124v1⟩
551 Consultations
281 Téléchargements
