Efficient Arbitrary Sample Rate Conversion for Multi-Standard Digital Front-Ends - Artificial Intelligence Lab, IRT b<>com Accéder directement au contenu
In this paper, we study the hardware implementation of arbitrary sample rate conversion (ASRC) using recently proposed variable fractional delay filter (V-FDF) structures. The most commonly used solution to implement V-FDFs has been the Farrow structure for the last three decades. In this work, we develop and compare the implementations of different recently proposed V-FDF options based on the Newton structure. These implementations are done on both ASIC and FPGA targets. The obtained results show that the recently proposed solutions offer better ASRC performance while using up to 3 times less resources relatively to the classical Farrow structure. The generic nature of these filters make them suited for a large number of standards.
NEWHRW.pdf (481.57 Ko) Télécharger le fichier
hal-02124512 , version 1 (09-05-2019)
Ali Zeineddine, Stéphane Paquelet, Amor Nafkha, Pierre-Yves Jezequel, Christophe Moy. Efficient Arbitrary Sample Rate Conversion for Multi-Standard Digital Front-Ends. IEEE NEWCAS Conference 2019, Jun 2019, Munich, Germany. ⟨10.1109/NEWCAS44328.2019.8961230⟩. ⟨hal-02124512⟩
134 Consultations
476 Téléchargements
